No entry for META-INF/context.xml exists
Postby ViperRacer2002 » Fri Dec 15, 2006 11:23 pm
I've searched through the forums and tried all of the different options, but to no avail, I still receive errors when deploying the war. Note, I installed Tomcat5 though apt-get.
OS: Ubuntu 6.06
Here are the errors I've been seeing when deploying the WAR file through the Tomcat Web Application Manager this is what I received:
FAIL - Encountered exception java.io.IOException: No entry for META-INF/context.xml exists.
When I try to start the application through the same page I receive this error:
FAIL - Application at context path /subsonic could not be started
Here are my entries out of the log files in /usr/share/tomcat5/logs:
catalina_2006-12-15.log
INFO: Installing web application at context path /subsonic from URL file:/var/lib/tomcat5/webapps/subsonic
log4j:WARN No appenders could be found for logger (org.apache.commons.digester.Digester).
log4j:WARN Please initialize the log4j system properly.
Dec 15, 2006 6:03:18 PM org.apache.catalina.core.StandardContext start
SEVERE: Error listenerStart
SEVERE: Context startup failed due to previous errors
localhost_2006-12-15.log
2006-12-15 18:02:28 StandardContext[/manager]HTMLManager: install: Installing web application from 'jar:file:/var/lib/tomcat5/webapps/subsonic.war!/'
2006-12-15 18:02:28 StandardContext[/manager]HTMLManager: ManagerServlet.configure[jar:file:/var/lib/tomcat5/webapps/subsonic.war!/META-INF/context.xml]
   at gnu.java.net.protocol.jar.Connection.connect (Connection.java:137)
   at gnu.java.net.protocol.jar.Connection.getInputStream (Connection.java:146)
   at org.apache.catalina.manager.ManagerServlet.deploy (ManagerServlet.java:851)
   at org.apache.catalina.manager.HTMLManagerServlet.deployInternal (HTMLManagerServlet.java:271)
   at org.apache.catalina.manager.HTMLManagerServlet.doPost (HTMLManagerServlet.java:251)
   at javax.servlet.http.HttpServlet.service (HttpServlet.java:709)
   at javax.servlet.http.HttpServlet.service (HttpServlet.java:802)
   at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter (ApplicationFilterChain.java:252)
   at org.apache.catalina.core.ApplicationFilterChain.doFilter (ApplicationFilterChain.java:173)
   at org.apache.catalina.core.StandardWrapperValve.invoke (StandardWrapperValve.java:214)
   at org.apache.catalina.core.StandardValveContext.invokeNext (StandardValveContext.java:104)
   at org.apache.catalina.core.StandardPipeline.invoke (StandardPipeline.java:520)
   at org.apache.catalina.core.StandardContextValve.invokeInternal (StandardContextValve.java:198)
   at org.apache.catalina.core.StandardContextValve.invoke (StandardContextValve.java:152)
   at org.apache.catalina.authenticator.AuthenticatorBase.invoke (AuthenticatorBase.java:540)
   at org.apache.catalina.core.StandardValveContext.invokeNext (StandardValveContext.java:102)
   at org.apache.catalina.core.StandardHostValve.invoke (StandardHostValve.java:137)
   at org.apache.catalina.valves.ErrorReportValve.invoke (ErrorReportValve.java:118)
   at org.apache.catalina.core.StandardEngineValve.invoke (StandardEngineValve.java:109)
   at org.apache.catalina.core.ContainerBase.invoke (ContainerBase.java:929)
   at org.apache.coyote.tomcat5.CoyoteAdapter.service (CoyoteAdapter.java:160)
   at org.apache.coyote.http11.Http11Processor.process (Http11Processor.java:799)
   at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection (Http11Protocol.java:705)
   at org.apache.tomcat.util.net.TcpWorkerThread.runIt (PoolTcpEndpoint.java:577)
   at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run (ThreadPool.java:684)
   at java.lang.Thread.run (Thread.java:674)
   at java.lang.VMThread.run (VMThread.java:123)
2006-12-15 18:02:28 StandardContext[/manager]HTMLManager: list: Listing contexts for virtual host 'localhost'
Any help would be great.
Server Information
Tomcat Version    JVM Version    JVM Vendor    OS Name    OS Version    OS Architecture
Apache Tomcat/5.0    1.1.6    Kaffe.org project    Linux    2.6.15-26-server    i386
ViperRacer2002
Postby ViperRacer2002 » Sat Dec 16, 2006 3:06 am
Ok, I got it to work.
First I added a repository for java:
deb http://seveas.imbrandon.com dapper-seveas java
deb-src http://seveas.imbrandon.com dapper-seveas java
note: you need to run the below command also:
wget http://seveas.imbrandon.com/1135D466.gpg -O- | sudo apt-key add -
Next, I updated apt, and installed the needed java packages:
sudo apt-get update
sudo apt-get install sun-j2re1.5
sudo apt-get install sun-j2sdk1.5
Then I edited the /etc/default/tomcat5 file with the below:
sudo vi /etc/default/tomcat5
After:
#JSSE_HOME=/usr/local/jsse
Add:
JAVA_HOME=/usr/lib/jvm/java-1.5.0-sun
All of this was done with and install of Tomcat5 with Ubuntu Dapper with the below command:
sudo apt-get install tomcat*
The default install uses "kaffe" java which was causing my problems. At some point I'll clean this up and make a nice how-to for Ubuntu Dapper users. So far I haven't had any problems.
ViperRacer2002
Users browsing this forum: No registered users and 70 guests
