Java & MediaMonkey
Java & MediaMonkey
Postby andy51 » Wed Feb 17, 2010 1:22 pm
I've just installed 3.9 to use with MediaMonkey. I'm getting the Java memory error
java.lang.OutOfMemoryError
Message Java heap space
Java version Sun Microsystems Inc. 1.6.0_11
Operating system Windows XP 5.1
Server jetty-6.1.x
Memory Used 63 of 63 MB
Stack trace java.lang.OutOfMemoryError: Java heap space
Advice on other posts is to modify the subsonic.sh file. Where do I find this file?
andy51
Postby Poffa » Wed Feb 17, 2010 7:51 pm
subsonic.sh is for Linux and Mac users. You should probably look for the setting somewhere here:
It installs Subsonic as a service, available in Control Panel > Administrative Tools > Services, that is started automatically when you log on to Windows.
It also creates links in the Start Menu: Start > All Programs > Subsonic. From this menu you can start/stop the Subsonic service, open the Subsonic web page, or change basic settings such as which port number Subsonic should use. You can also click on the little yellow submarine tray icon.
Poffa
Postby andy51 » Wed Feb 17, 2010 9:36 pm
Thanks.
I altered the memory limit in 'Settings' in the control panel and that seems to have done the trick.
andy51
