Android player unable to connect
Postby rage4order » Wed Feb 17, 2010 7:56 pm
I have a licensed Subsonic version 3.9 installed on my home server. Recently, I upgraded the Android application (running on Nexus One) but now I am not able to connect to my server. It fails every time with the following error message:
Connection failure. Illegal character in query at index 53: http://najdrovsky.com:8080/subsonic/res ... &c=android
Could I get some suggestions how to fix this? Prior to upgrading to the current app, I was able to connect. The web application itself working fine in a browser, only the Android app seems to have a problem.
rage4order
Postby reddragon72 » Sat Feb 27, 2010 4:12 am
mine is an illegal character in authority at index 22.
need help! I can get to subsonic VIA the browser, but the app always gives me this error.
thanks
reddragon72
Postby flyguy » Wed Mar 10, 2010 6:57 pm
Same problem..mine is an illegal character in authority at index 27.
I installed on a vista machine and can get to my archived music and play it fine on that computer.
I installed the android app and get the above error when trying to connect. The server address I use is http://[my server name].subsonic.org. Is this right?
For s&g's, I pointed the droid browser to that address and subsonic comes up with my music catalog, but it won't play anything.
flyguy
Postby rage4order » Tue Mar 16, 2010 9:30 pm
bump....
I was hoping Sindre would reply to this by now. I paid for the Subsonic registration specifically so that I could stream to my Android phone (Nexus One). As it stands, it simply does not work.
rage4order
Postby sindre_mehus » Wed Mar 17, 2010 9:46 am
Hi and sorry for overlooking this post.
I've analyzed this problem and I think it could happen if you have entered a whitespace before or after the server address or username in the server settings.
Can you please check that?
Thanks.
Postby rage4order » Wed Mar 17, 2010 12:42 pm
Yes! That was it. Somehow, a space got *in front* of my login name. Must have been some sort of soft keyboard snafu. Thanks for the reply!
rage4order
Postby sindre_mehus » Wed Mar 17, 2010 1:01 pm
No problem. I will make sure to automatically trim these values in the next version.
Postby gr8fuljonnyd » Thu Mar 25, 2010 2:35 am
I am having a similar issue.
Do I put in myusername.subsonic.org or my ip address on my droid app?
gr8fuljonnyd
Postby chip11under » Tue Mar 30, 2010 5:15 pm
I get Connection Failure. Socket is not connected
chip11under
Android App not connecting
Postby Jennajon » Tue Mar 30, 2010 5:25 pm
chip11under wrote:I get Connection Failure. Socket is not connected
Count me as a ditto for this same error message. :shock:
Jennajon
Postby chip11under » Tue Mar 30, 2010 6:00 pm
FYI I get "Connection OK" for "Subsonic Demo".
I have port forwarded using port 80. Made firewall program exceptions with the port too
chip11under
