Songs in 64k WMA for stop playing early (half way through)
Postby paulson7 » Wed Feb 24, 2010 3:17 am
I continuously experience the problem where every song in my library that is in the 64k wma format stops playing approximately half way through as if the software thinks the song is finished (it begins playing the next song). This does not occur for any other format that I've used and I can find no other pattern that might explain the problem.
Any ideas?
KP
paulson7
Follow Up
Postby paulson7 » Thu Mar 11, 2010 1:33 am
The problem also occurs with respect to directly downloading songs. For example, if I download an entire album of songs that are all in the 64k wma format, each song only has approximately half of its entirety. If a song is 3 minutes, 25 seconds long (for example) the downloaded song will only be the first 1 minute, 44 seconds of that song. This does not occur for any other format.
paulson7
Postby sindre_mehus » Thu Mar 11, 2010 4:50 am
If I remember correctly this was fixed in Subsonic 3.9, so, if you haven't already done so, please upgrade.
Cheers,
