Problem with Playlists
Postby tanne24 » Wed Feb 24, 2010 4:10 pm
I just installed Subsonic for testing and in gerneral everything is fine so far.
My problems are about playlists:
a) Relative paths in playlists not working:
When I now try to load a playlist, I got this error message in logfile:
WARN PlaylistService Access denied to file \Music\
For testing I created a playlist with absolute pathname (d:\music\), this works fine.
In Subsonic configuration I set default path for music to "d:\music\" and for playlists to "d:\playlists\".
Is there a possibilty in Subsonic to handle relative pathnames?
b) Also, I have subdirs in my playlist folder, these are not shown in Subsonic. In path configuration I tested "d:\playlists\;d:\playlists\compilations", but this throws errors. Is there a possibilty to have more than one playlist folder?
Many thanks for your reply.
tanne24
P.S. If these problems will be solved, I will donate for sure, as this is really a good application.
tanne24
Postby 3R3 » Wed Mar 17, 2010 9:52 am
:-) looks like you want to commission work on the playlist features?
but yeah, the playlist-handling right now is mostly for playlists created by subsonic.
3R3
