SubAir Problem
SubAir Problem
Postby deejay2302 » Thu Feb 25, 2010 11:32 pm
Hi Sindre. I use Subair and have a Problem with Download in Field Search.
When I right click I do not download in this box. Is this normal?
Unfortunately, the search brings me nothing if I can not download there :(
And the Next Problem is.. The search of tracks takes longer than in the subsonic. Is it because not to do something so the quicker?
In my Subsonic are now over 93,000 tracks and then it takes a bit longer to find something. And Subair is even slower :?
I can also give you an account and send you the data so that it can test. Still need to enter into my subsonic over 300,000 tracks. Only if this is already slow, I do not know how it is when all the track are available.
My System:
Win7 Enterprise
AMD Dualcore 2,8GHZ
3 GB Ram
Upload: 1024 Kbit/s
Download: 14 Mbytes/s
For Subsonic Ram: 250Mbyte
21.681 Artists
58.141 Albums
674.091 Songs
5072,14 GB (~ 49.341 Hours)
deejay2302
Postby pha9992001 » Fri Feb 26, 2010 5:40 am
download is currently not enabled in the search tab. this will be enabled in the next release.
pha9992001
Postby deejay2302 » Thu Apr 08, 2010 7:34 pm
Ah ok Thanks :D
21.681 Artists
58.141 Albums
674.091 Songs
deejay2302
