Help, I can't make this program work.
Postby brantleyb » Fri Feb 26, 2010 3:38 pm
Hi, I'm Brantley.
So, I downloaded subsonic thinking I could use it to stream music from my home/work computer to my HTC hero on the sprint network. I feel like I am close but it is just not happening.
A couple of questions:
My work computer is not on a router. There is a wireless router here, but my computer is not connected to it. I guess they are on the same network? Is this an issue?
On my phone, I can get to the select server screen, but which one do I choose to connect to my computer?
Basically, I feel like I am missing an important step. Should I be trying to log in with this
" Access your server over the Internet using an easy-to-remember address. " or should the android app help me skip this step?
I'm confused and I feel retarded. I will gladly donate if that is what I'm missing to make this work.
brantleyb
Postby 3R3 » Thu Mar 11, 2010 5:05 pm
you dont need the android app except for use with android.
theres already an excellent guide on setting up subsonic for remote access here http://forum.subsonic.org/forum/viewtopic.php?t=2634
3R3
