"ConnectTimeoutException" Error
Postby allyjweir » Tue Mar 02, 2010 6:05 pm
Hey all,
Yesterday I reinstalled Windows 7 Professional and then had to install subsonic again. I have ran into a problem which has caused me a fair bit of hassle and would be great if i could get some help with
When using the Web UI, I go into the network settings and try to set up my 'yourname.subsonic.org' address thing but every time i click test it comes up saying it is registered, but could not connect to it(ConnectTimeoutException)
Does any one have any ideas on how to solve this?
My thought was that i was using the same address as i did on the old computer but i tried changing it and got the same error.
Thanks in advanced for any help guys :)
Subsonic is soooo cooooool
allyjweir
Postby toolman » Tue Mar 02, 2010 11:05 pm
You could try this:
Under networkoptions:
tick the box configure my router........
Also fill in the public port number you are using. Default is 80.
Then proceed to the step where you configure your subsonic.org adress.
toolman
Postby allyjweir » Tue Mar 02, 2010 11:21 pm
I tried this and changed it to what i used to use successfully. Port 81. Still couldn't get it to work.
I'm not very network literate so sorry if this is a simple fix I have complicated with my incompedence
allyjweir
hi
Postby buellie » Tue Mar 02, 2010 11:37 pm
didnt work for me either
i tried port 80 and 81
buellie
Users browsing this forum: No registered users and 87 guests
