No tray icon, can't change port [3.9]
Postby chris.h » Tue Mar 09, 2010 1:27 pm
I upgraded to 3.9, the app started but switched to port 80 saying that 8080 was in use.
I restarted the computer and now the tray icon won't run. It's stuck on port 80 and I can't get the tray app to run to switch to 8080.
If hit run subsonic, it opens my browser but just takes me to the server I have running on port 80.
The web view opened up in my browser after the restart, and under network I enabled port forwarding and changed it to 8080 but the log said no router found so I disabled it.
Any ideas?
UPDATE: I reinstalled to get the window back. Hopefully it continues to work after a restart.
chris.h
Postby deejay2302 » Wed Mar 10, 2010 2:25 pm
2 Ideas:
-U have stopped ur subsonic service before?
-Write Rights on ur system ?
-----------------------------test this----------------------------------
Stop Server
Switch port manually in Folder X://subsonic/subsonic.proberties
open with text editor and write port to:
PortForwardingLocalPort=8080
Start Server.
21.681 Artists
58.141 Albums
674.091 Songs
5072,14 GB (~ 49.341 Hours)
deejay2302
Users browsing this forum: No registered users and 42 guests
