video and music = 2 installs
Postby reddragon72 » Thu Mar 11, 2010 3:55 pm
Ok I have a Subsonic install for music right now, but I want to have another one for Videos. I tried combining them, but it was just to confusing on what was what. So has anyone installed Subsonic twice? I mean has anyone installed it to two seperate directories and had two login locations? I want to split my movies from my music and two installs seems to be the only way, but I don't want to crash my current install if this is not possible.
thanks
reddragon72
Postby 3R3 » Thu Mar 11, 2010 4:13 pm
on what os are you planning to do this? basically, for ease of use/installation of the 2nd install you would use the standalone version, just create another directory, asign it another port (forward it etc...), and you're set.
3R3
Postby reddragon72 » Thu Mar 11, 2010 8:52 pm
I have a Windows Home server setup. I used to have a Windows mobile phone and used webguide to stream my movies and tv shows. Well now I have an Android phone and it doesn't do WMV streaming so I have to devise a new way to stream my videos. I have asked on several forums if I can change the way webguid streams, but I have not received a single bit of help. So now I am off to find a new route to go and figured if I could get HTML5 to work in the web page of subsonic to replace flash then I can get my videos reencoded on the fly and streamed in H264 to my phone. Android doesn't do flash and even then I'm not sure I want flash with the new video tag in HTML5. So I am either going to try and replace the current flash player with HTML 5 player or just make a new subsonic and replace the player there with either a simple link to the video or html5 video.
reddragon72
Postby reddragon72 » Fri Mar 12, 2010 7:55 pm
I found a HTML5 player with fall back capability to flash if needed. Here is the code.
<!-- "Video For Everybody" v0.3.2
<!-- first try HTML5 playback. if serving as XML, expand `controls` to `controls="controls"` and autoplay likewise -->
<video width="640" height="360" poster="__POSTER__.JPG" controls>
   <!-- you must use `</source>` to avoid a closure bug in Firefox 3 / Camino 2! -->
   <source src="__VIDEO__.OGV" type="video/ogg"><!-- Firefox native OGG video --></source>
   <source src="__VIDEO__.MP4" type="video/mp4"><!-- Safari / iPhone video    --></source>
   <!-- IE only QuickTime embed: IE6 is ignored as it does not support `<object>` in `<object>` so we skip QuickTime
        and go straight to Flash further down. the line break after the `classid` is required due to a bug in IE -->
   <!--[if gt IE 6]>
   <object width="640" height="375" classid="clsid:02BF25D5-8C17-4B23-BC80-D3488ABDDC6B"><!
   [endif]-->
   <!-- non-IE QuickTime embed (hidden from IE): the self-closing comment tag allows non-IE browsers to
        see the HTML whilst being compatible with serving as XML -->
   <!--[if !IE]><!-->
   <object width="640" height="375" type="video/quicktime" data="__VIDEO__.MP4">
   <!--<![endif]-->
   <param name="src" value="__VIDEO__.MP4" />
   <param name="showlogo" value="false" />
   <param name="autoplay" value="false" />
   <!-- fallback to Flash -->
   <object width="640" height="384" type="application/x-shockwave-flash"
      data="__FLASH__.SWF?image=__POSTER__.JPG&amp;file=__VIDEO__.MP4">
      <!-- Firefox uses the `data` attribute above, IE/Safari uses the param below -->
      <param name="movie" value="__FLASH__.SWF?image=__POSTER__.JPG&amp;file=__VIDEO__.MP4" />
      <!-- fallback image. download links are below the video. warning: putting anything more than
           the fallback image in the fallback may trigger an iPhone OS3+ bug where the video will not play -->
      <img src="__POSTER__.JPG" width="640" height="360" alt="__Title of video__"
           title="No video playback capabilities, please download the video below"
   </object><!--[if gt IE 6]><!-->
   </object><!--<![endif]-->
</video>
<!-- you *must* offer a download link as they may be able to play the file locally. customise this bit all you want -->
<p>Download Video: <a href="__VIDEO__.MP4">Apple iTunes "MP4"</a> | <a href="__VIDEO__.OGV">Open Format "OGG"</a></p>
(If you would like your video to automatically start playing, check out the sample code on the test page.)
Here’s a compacted version as an example:
(Technically only one line break is required to deal with an IE bug on line 4)
   <source src="__VIDEO__.OGV" type="video/ogg"></source>
   <source src="__VIDEO__.MP4" type="video/mp4"></source><!--[if gt IE 6]>
   [endif]--><!--[if !IE]><!-->
   <!--<![endif]-->
           title="No video playback capabilities, please download the video below" />
   </object><!--[if gt IE 6]><!--></object><!--<![endif]-->
</video>
The only issue is that I am not sure where to put this since Subsonic seems to be done in javascript and this is standard HTML. Anyone have any input?
Also look at the code there is a full explanation at the top and a compact version at the bottom. I tested this on a quick site I put up an it works fine, but there is no transcoding and I don't want to have to recode all my movies just for my cellphone.
thanks for any help anyone can shed on this.
reddragon72
Postby 3R3 » Sun Mar 14, 2010 2:04 am
well, duh! sorry but i never tried to stream video with subsonic. i only read over a few threads here that modded the jwplayer config and use ffmpeg to transcode on the fly...
but there ARE a few threads on here with people modding subsonic to be better suited to play video, i bet someone there has thought about html5, just search for it.
also, i dont have the hardware to test this, so i can only wish you good luck with this!
3R3
2 installs
Postby sahra » Wed Mar 17, 2010 4:38 pm
Hi 3r3
how would you do that?
copy c:\subsonic\ to c:\subsonic_video\
How would it start automatically?
Where do I chnage the port? in the subsconic.proberties file i just found the PortForwardingPublicPort=4850 not the internal one (port 80)
thnaks for help sahra
sahra
Re: 2 installs
Postby lazy » Wed Mar 17, 2010 8:25 pm
Hi 3r3
I think they are talking about installing the standalone version to another directory. I would not copy your current working directory.
lazy
Postby 3R3 » Wed Mar 17, 2010 9:54 pm
yeah, i meant a separate install. change the port while/after installing the second version. with the standalone version, under windows i believe there is a .bat file which you have to edit. just enter your port there. there should also be a readme included with further details. sorry to be so vague, but i only have subsonic running under linux, its been some time since i ran it under windows and some things might have changed. but just give it a try, its relatively well documented/commented.
3R3
