File Permissions
File Permissions
Postby colli419 » Wed Mar 17, 2010 5:16 am
Hi All:
I have installed a standalone Subsonic server on my new box. I was wondering if anybody knew what the folder/permission associations were. Meaning, which files need to be root for Subsoonic to function and which can be owned by users other than root.
colli419
Postby 3R3 » Wed Mar 17, 2010 9:04 am
you dont have torun subsonic as root, just make sure that the the folders/files it has to access are accesible by the user that is running subsonic. for example /var/subsonic is only accesible by root by default, but you can change the permissions and then just run it as any user you like.
3R3
Postby colli419 » Wed Mar 17, 2010 2:04 pm
Okay that sounds good. But for clarification, if my user is "mike" and I set all my files to be owned by "mike" with no group will it run the same?
colli419
Postby 3R3 » Wed Mar 17, 2010 3:58 pm
well, i encountered strange behaviour sometimes, so to be sure i also set the group to be "mike"
3R3
Postby colli419 » Wed Mar 17, 2010 4:43 pm
That is weird because I was able to set the group to whatever my heart desired. Needless to say I got impatient and just tried messing around with the groups and users in the folder and found that it worked just fine. Thanks though.
colli419
