Subsonic cannot start
Postby DToX » Fri Mar 19, 2010 5:15 am
Okay so the other day I noticed my Subsonic application would not connect to my server, the server is running off my home computer anyway I got home and found subsonic not running as my computer rebooted and for some reason the program did not auto launch.
Now I cannot get it to start at all, I've uninstalled the program and searched my hard drives for anything with "subsonic" and deleted anything i could think or in hopes something would help
clicking start subsonic service does nothing nor does start subsonic tray
I am out of ideas guys please someone tell me i'm over looking something, I reinstalled the application like 20times tonight
DToX
Postby burjast » Fri Mar 19, 2010 9:52 am
erase java cache, or most probably try to delete /db folder inside subsonic, maybe data is corrupted and subsonic cannot start. I say this, because i believe in your process of reinstalling you didn't remove subsonic.. If that doesn't work, log file would be most helpful
burjast
Postby DToX » Fri Mar 19, 2010 8:24 pm
can you tell me where the files are located? log file etc
I uninstalled subsonic many times, i also deleted the subsonic folder in my programs
C:\Program Files (x86)\Subsonic
DToX
Postby DToX » Fri Mar 19, 2010 8:36 pm
Okay after beating my head I figured out the problem, I was a java test in firefox and it killed the firefox process so I knew it was a java problem.
Reinstalled java and now it works, thanks for your help
DToX
Postby bengrulz » Sat Apr 03, 2010 11:28 pm
same issue here, same solution, thanks!!
bengrulz
