Last.fm Searches
Last.fm Searches
Postby colli419 » Sat Mar 20, 2010 6:59 pm
Hi All:
When I try and search an album or song directly from Subsonic. I get the following output in the Last.fm search bar:
%22John Legend%22 %22Get Lifted%22
I understand the purpose of the %22's in html code but they shouldn't be there in this case. Is there a way to get rid of them so that the search will work?
colli419
Postby deejay2302 » Sat Mar 20, 2010 7:10 pm
Thats an symbol/character (Hex Symbol)
Normally, I know the only mp3 files which you have downloaded somewhere.
And normally is the symbol " in the name of files not allowed in Windows.^^
Example:
%28 = (
%29 = )
%20 = Space
%26 = &
%7D = }
%7B = {
etc......
U understand ?
*EDIT* The symbol is this:
%22 = "
List for more Codes:
http://www.ascii.cl/
*EDIT2*
Ahh. I understand ur problem. I have test it. When im in a Musicfolder and the click over the Tracklist on last.fm then make subsonic this symbols to searchfield. I mean thats an Bug. I have same problem.
Anyone have an Bug Fix?
The Problem are the Symbols of Subsonic. He copy Symbols to last.fm.
Look here:
h**p://ww*w.last.fm/music/?q=%22B%C3%B6hse+Onkelz%22+%22Dopamin%22&m=albums
Thats the direct link to last.fm from an Album from me.
Sindre can helps?
21.681 Artists
58.141 Albums
674.091 Songs
5072,14 GB (~ 49.341 Hours)
deejay2302
Postby sindre_mehus » Sun Mar 21, 2010 7:15 am
I'll try to fix that. Thanks for reporting it :-)
Postby colli419 » Sun Mar 21, 2010 5:25 pm
Thanks Sindre and Deejay.
colli419
