Folder not being added
Postby twiffy » Sun Mar 21, 2010 5:08 pm
I've set up the server client and the android app, and both are working perfectly, with the one exception that when I add my music folder via the web interface, the content doesn't update.
Now, I added a folder for Audio Books, and another folder for TTC Lectures, and those were added to the available content right away, and I can see that content and play it over my phone. But when I add my music folder, although the folder gets listed in the "Music Folders" page of the web interface, on the left where you view content and can select a specific folder, none of the content shows, and the folder isn't an option in the drop-down "select folder" box.
Of course I've tried deleting the folder and then re-adding it -- no go.
Is folder size an issue? This folder is about 400 GB. I tried adding a subfolder that is 130 GB and it had the same problem, but the TTC Lectures is 95 GB and works fine.
All these folders are shared on my local network, and are also being shared / indexed by Orb. Can't imagine this makes a difference. Anyone have any ideas????
twiffy
Never mind!
Postby twiffy » Sun Mar 21, 2010 5:10 pm
Oh man, I'm a retard! The folder was labeled as "My Music" in Windows Explorer, but actually had a path of \Music. I checked this in the command prompt, switched it over, and it's working great.
twiffy
