3 Issues here
3 Issues here
Postby NickBriz » Sun Mar 21, 2010 6:03 pm
Hi, love subsonic great program
The 2 issues I'm having are:
1. I have 1 music folder with about 12,000 mp3s in it, and it will not display in subsonic, is there a way without seperating the folder to view them? I have been just using search to find songs
2. I get an Error message everytime I load subsonic (Just says Error and OK button), which stops the right bar from showing users online
3. Issue with total MB, it says i have over 35,000 total in 1 day... is this possible? I havent been streaming constantly either
Any help appreciated
NickBriz
Postby 3R3 » Mon Mar 22, 2010 12:19 pm
about 1.
Subsonic expects music in separate folders, and displays those in the left pane. if you want album/whatever showing there, you have to get sorting, meaning the subsonic folder structure is not dependent on tags but on actual structure of your music folders. if theres no subfolders in your main folder, nothing will appear in the left pane. good tools to automate this task (provided its well tagged^^) are mediamonkey or foobar2000.
2. maybe subsonic has a limit loading files per folder. for testing make a folder with 50 or so mp3s and set this as main music folder (and only one). maybe this resolves 2.
3. mmh, strange, but you best resolve the first two isssues to make sure subsonic is working correctly. if it's still there (and you really havent streamed this much, maybe left it on over night or something like that) it's worth looking into.
3R3
Postby NickBriz » Tue Mar 23, 2010 12:42 am
Thanks for your reply, i actually got on today and changed the theme and the 2nd error stopped happening, as for my music folder, i do have like 20 albums too which shows just fine, ill keep it like it is because I can still access songs I want with search.
The third issue is still hapenning, its up to 50,000 mb.. I run the server on a 30down 5up connection and its running windows server 2008, I still have no clue how this is possible
NickBriz
Re: 3 Issues here
Postby Aethies » Tue Mar 23, 2010 2:41 pm
NickBriz wrote:Hi, love subsonic great program
1) - Did you add that path in Settings | Music Folders? Also, make sure the file extensions are added on the General section under Music Mask.
2) I noticed I get this error message about after a week or so.. so I have to restart the server and it goes away. Not sure what this is doing.
3) Sorry.. Not sure.
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
2636.09 GB (10,769 hours)
Aethies
