Song won't start on its own
Postby bengrulz » Sun Mar 28, 2010 4:03 pm
I'm having a somewhat confusing problem using the web player. For the majority of my files, everything works fine.
This problem is only occuring (as far as I can tell) on mp3's I purchased using Zune marketplace. These are 256 or 320kbps mp3 files with NO drm.
Symptoms: (I have verified this problem on two computers from both within the same network and over the internet.)
*When I go to play them in the web interface and the flash player, they don't play. The play icon changes to pause icon for a quarter second, then switches back to play.
*If I click the seek bar somewhere within the song, it plays fine.
*Behavior is the same between Firefox and IE.
*If I set the web player to limit bitrate to anything below 320kbps, it plays when I click play, but the audio is greatly slowed down.
*Playing the song from the android app works perfectly.
*Playing the song using the local player instead of the flash player works perfectly.
I'm using Windows Vista and Subsonic 3.9
Any suggestions?? Can anyone test Zune purchased mp3s??
bengrulz
I am having this same problem
Postby randregL » Tue Apr 20, 2010 11:59 pm
and wondered if anyone else had come up with a solution?
I am using an iPhone with the website connection. It recognizes my files, shows artwork, but cycles through an album's song in seconds with no sound at all.
Thanks. :cry:
randregL
Kicking one more time, hoping for a solution.
Postby randregL » Wed Apr 21, 2010 11:40 pm
I have a LARGE library, probably close to 90GB, is that part of the problem?
randregL
Re: Kicking one more time, hoping for a solution.
Postby oeh » Wed Apr 21, 2010 11:49 pm
randregL wrote:I have a LARGE library, probably close to 90GB, is that part of the problem?
No, that is not the problem. I have just above 250 GB (for now) and it works like charm.
@randregL
What system are you running on?
@Both
Have you checked out the logs?
@Both
Are all the transcoding parameters been sett as they should be?.
Regards
OEH
oeh
Well, let's see...
Postby randregL » Fri Apr 23, 2010 12:05 am
I'm using an iPhone 3GS, 16GB newest model, running XP on a wifi-enabled laptop.
I've left the transcoding parameters at the installation default.
I found this in the log:
INFO: The CacheManager shutdown hook is enabled because net.sf.ehcache.enableShutdownHook is set to true.
Apr 22, 2010 6:36:41 AM net.sf.ehcache.Cache initialise
WARNING: Cache: chatCache has a maxElementsInMemory of 0. It is strongly recommended to have a maximumSize of at least 1. Performance is halved by not using a MemoryStore.
WARNING: Cache: musicFolderCache has a maxElementsInMemory of 0. It is strongly recommended to have a maximumSize of at least 1. Performance is halved by not using a MemoryStore.
I don't know how to change these size settings.
randregL
Kicking and hoping for an answer!
Postby randregL » Fri Apr 23, 2010 5:16 pm
nt
randregL
One more kick, still hoping for a solution.
Postby randregL » Sun Apr 25, 2010 2:17 am
nt
randregL
Postby deejay2302 » Sun Apr 25, 2010 7:46 pm
I mean is the Memory Space (Ram) or the HDD Space. He have not enough memory. Or not?
Memory = Ram
Cache = HDD
Test it with "more Ram" Settings
Or am I mistaken?
21.681 Artists
58.141 Albums
674.091 Songs
5072,14 GB (~ 49.341 Hours)
deejay2302
Another kick....
Postby randregL » Tue Apr 27, 2010 2:51 am
I have my music on a standalone hard drive. I changed its settings to where it would cache on the computer for better performance; however, I still am getting the same errors as before.
I really would appreciate whatever help anybody can give.... :cry:
randregL
Postby jerrodbug » Tue Apr 27, 2010 8:44 pm
same exact issue. windows 7 64 bit, but that shouldnt matter, since im using the web browser player. i am using firefox.
also, it is only certain songs. if i click to skip ahead then the song will start playing from that point on.
jerrodbug
Users browsing this forum: No registered users and 38 guests
