simply not working! plays only 2 seconds..
Postby arfo » Fri Apr 02, 2010 3:17 pm
hi everyone,
I am a subsonic user for around 2 years now and even donated. I haven't reinstalled it on a fresh OS for some months though and tried to give it a shot.
anyway, although it has been working for me half a year ago, this fresh installation on my WindowsHomeServer gives me a headache. I tried both the standalone version and a deployment on Tomcat. Both worked so far when I use the integrated flash player. BUT as soon as I select to play to an external player (tried VLC and Win Media Player), it simply does not work:
* first way:
I connect VLC to the stream http://server:port/stream?player=2&suffix=.mp3
It connects and shows correctly "welcome to subsonic.."
Then I open the web interface, add some songs and click "play"
* second way:
I open the web interface and add some songs and click "play"
VLC opens with the M3U (automatically)
=> both ways' result/problem:
VLC plays 0-2 seconds and then disconnects completely. This happens again when I press play in VLC to reconnect.
Win Media Player is even more weird: It plays a while, but the songs in subsonic seem to skip automatically after 5-10 seconds, through the playlist. after some songs, winmediaplayer just stops.
What only seems to work (but is not usable for me because I want to connect my Popcorn Hour C200 to the mp3-stream) is the flashplayer and the external-playlist-option.
My WHS is capable enough (worked with ealier versions some time ago), my network is Gbit/WLAN combined, my client PC is a Windows 7 Pro Laptop. Firewalls are all configured properly (even tried to turn them off completely). Memory is enough there and I gave up to 500MB to the standalone version. No change.
I am totally confused, can someone help me out?! :shock:
arfo
Postby arfo » Sat Apr 03, 2010 10:17 am
Nobody out there with the same problem?
If you're too lazy to read my first post (I wrote too much eh?): "External Player"-usage in the web-interface is not working.. :roll:
heeelp!
arfo
Postby sindre_mehus » Sat Apr 03, 2010 8:17 pm
I don't know; just tested it now and it worked fine. This was on a Mac with Safari and iTunes.
Anyone else having problems?
Postby arfo » Sun Apr 04, 2010 11:25 am
hi sindre, thanks for your message!
well, seems like this is mostly VLC-related, as in http://forum.subsonic.org/forum/viewtopic.php?t=2333 also had that problem.
gonna have to live with that. since I actually wanted to connect my popcorn hour to the stream I wonder now, is there a possibility to change the stream or generate a different kind than mp3 over http? maybe mms? could that solve the problem both for VLC and my PCH?
anyway, I love your work, thank you very very much for this!
arfo
same here
Postby dudealfred » Tue Apr 20, 2010 7:29 am
same problem here. the server is 9.04 linux.
On Client Ubuntu LInux (9.10) - Firefox or Chromium :
*The flash web player won't play any sound, and there's no progress on the bar, or anything else really.
*Additionally, when I try to read a playlist with VLC, it plays 2 seconds then stops, which kinda sucks
[*Finally, on my iTouch, Z-subsonic can't seem to be able to find my server, which also kinda blows ] --> this kinda solved itself, I think it was a funny firewall or something.
On Client Win7:
*flash player works like a charm
*VLC plays one second
=> So, does anyone have any idea how to fix any of it?
Someone Somewhere seemed to suggest augmenting the RAM subsonic can use, but I can't find where to do that.
Thanks a lot already :)
D.A.
dudealfred
Re: same here
Postby sindre_mehus » Wed Apr 21, 2010 7:44 am
dudealfred wrote:On Client Ubuntu LInux (9.10) - Firefox or Chromium :
Can you please check which version of the Flash plugin you have? Try upgrading it and see if it helps.
flash
Postby dudealfred » Wed Apr 28, 2010 1:48 pm
my flash version is : Shockwave Flash 10.0 r32 in chrome
can't really upgrade, but I saw 4beta1 fixed the problem. I'll try soon.
Cheers.
D.
dudealfred
Postby clayp » Thu Jul 01, 2010 12:03 pm
I had this problem for quite awhile. It didn't always happen and it happened most frequently with very large podcast files (>20mb). I checked my upstream bandwidth and it seemed to be very stable at ~420k. But If I checked the WAN throughput on my router, it fluctuated too much to support 256k streaming. Checking status in subsonic showed the same pattern.
Since I use DD-WRT firmware on my router, I tried tweaking DDWRT but it did not help. I checked for a new recommended firmware for my router in the DDWRT database and there was a new one, so I flashed the router with the new firmware. Since then I have had no issues with subsonic. Upstream bandwidth is unbelievably stable at 480 +/- 20.
clayp
