Server just doesn't work, and i can't figure out why.
Postby Demi » Sun Apr 04, 2010 7:57 pm
So, I set up Subsonic, and tested my domain [demi.subsonic.org] and yet, it's telling me that it's set up, but not working.
Status: demi.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException)
Anyone know how to fix this? It could be a port forwarding issue, but if it is, I have no idea how to fix it. I'm on Verizon FiOS if that helps. Thanks in advance! :)
-Demi
Demi
Postby ootuoyetahi » Mon Apr 05, 2010 10:40 pm
What port(s) is subsonic listening on? Have you opened this (these) port(s) on your routeR?
ootuoyetahi
Postby 3R3 » Mon Apr 05, 2010 10:46 pm
most of the time you have to let someone else test your servers availability from outside. just because you can not connect to your subsonic.org-adress from inside your lan, does not mean someone else cant connect from the internet.
3R3
Postby jcettison » Mon Apr 05, 2010 10:50 pm
3R3 wrote:most of the time you have to let someone else test your servers availability from outside. just because you can not connect to your subsonic.org-adress from inside your lan, does not mean someone else cant connect from the internet.
Eh, poor reasoning.
Even still, if you needed to test from outside you need not have an additional person, you can test through a proxy. Google will help you with many available free web proxies that should do the job fine.
Demi wrote:So, I set up Subsonic, and tested my domain [demi.subsonic.org] and yet, it's telling me that it's set up, but not working.
-Demi
Couldn't you just use your IP? Or is it dynamic?
You could always setup a service like DyDNS or whatever and forgo their subdomaining alltogether.
jcettison
Postby Demi » Mon Apr 05, 2010 11:46 pm
So, thanks for the replies, but I figured it out. Apparently, it was a port forwarding issue. I was forwarding to the wrong port.
Demi
