Embedded Player Not Working
Postby tmwsiy » Tue Apr 06, 2010 6:34 pm
I can't get the embedded player to work from web access.
When I play any song, even though my settings are for the player to be Web Player, I get a download prompt for an M3U file that I have to open with Windows Media Player (or whatever).
I am using Windows XP.
Any suggestions?
tmwsiy
Postby weav » Mon Apr 19, 2010 1:16 am
I had this happen to me today! I finally found that my problem was the player that was starting was the android player instead of the web player even though I was logging into Subsonic via browser. For some reason Subsonic would always use the android player for my user id! I confirmed it by noticing that the user agent string and timestamp for the player was not current as it should have been with me connecting via browser - but the android player had the user agent string for firefox and current timestamp!! I tried rebooting the server, reloading the pc's flash and java.. nothing would get the flash player to load.
I worked around this by creating a new mobile user that I only use on android and deleted the "android[username]" player that was associated with my normal user id. So now only "player#[username]" players show under my non-mobile user id.
Now the flash player loads correctly every time and I just make sure the android app uses only the new user-mobile id to connect.
I am new to Subsonic (just started using it yesterday - and already donated :D) but thought you could have multiple players per user without issue. I would think you can and this might just be a quirk.. maybe it is documented and I just didn't know about it yet.
Great streamer though.. so much fun to play with!
Hope it helps!!
weav
same here...
Postby dudealfred » Tue Apr 20, 2010 7:28 am
same problem here. the server is 9.04 linux.
On Client Ubuntu LInux (9.10) - Firefox or Chromium :
*The flash web player won't play any sound, and there's no progress on the bar, or anything else really.
*Additionally, when I try to read a playlist with VLC, it plays 2 seconds then stops, which kinda sucks
[*Finally, on my iTouch, Z-subsonic can't seem to be able to find my server, which also kinda blows] ------- > probelm fixed itself somehow. I think it was a funny firewall issue :)
On Client Win7:
*flash player works like a charm
*VLC plays one second
=> So, does anyone have any idea how to fix any of it?
Someone Somewhere seemed to suggest augmenting the RAM subsonic can use, but I can't find where to do that.
Thanks a lot already :)
D.A.
dudealfred
Postby usererror » Fri Apr 23, 2010 2:43 pm
I have the same issue from Ubuntu.
I also found that if I make a randomized playlist from the "More" menu page, the internal player does not work.
If I go directly to an album and click play all the internal player works great under Windows.
usererror
Postby sindre_mehus » Fri Apr 23, 2010 4:38 pm
Subsonic 4.0.beta1 solves the problem with the Flash player not working on Linux browsers.
Postby usererror » Mon Apr 26, 2010 2:51 pm
Before I try the beta, does it fix the issue too, with the built in player on the More > Random generated play lists not playing with the flash player?
usererror
Postby sindre_mehus » Mon Apr 26, 2010 8:00 pm
usererror wrote:Before I try the beta, does it fix the issue too, with the built in player on the More > Random generated play lists not playing with the flash player?
If your web browser is running on a Linux computer, then yes.
If I remember correctly, after create a random playlist on the "More" page, you have to click on the first song in the playlist to actually start playing. Have you tried this?
