Need Mac help
Need Mac help
Postby tr.slate » Tue Apr 06, 2010 8:52 pm
I could use some serious help getting subsonic up and running on os x 10.5. I have been able to connect internally using my comps ip and port, but i cannot reach the server from the outside world. I checked the plist and saw it was set at 4040, and made sure that my linksys router was also set to forward port 4040. I have tried adding the subsonic app to my firewall and allowing any incoming calls, but that doesnt work. I then set the mac to allow any incoming call at all, and this didnt work either.
am I missing something? I dont see a place to tell os x which port subsonic should connect to, or anything else...
I should mention that I am using subsonic with a custom DynDNS address, not the automagical setup.
tr.slate
Postby thomasbruce » Mon Apr 12, 2010 8:25 pm
do you have a modem/router from your internet provider? i have a netgear wireless router connected to a modem/router from my internet provider and i had to open ports on that router aswell to get it working.
thomasbruce
