External player with playlist --- show the song name?
Postby eli2k » Sun Apr 11, 2010 10:48 pm
I have the player settings set to "External player with playlist" which makes each song in the Subsonic playlist a playlist item, and saves it as a M3U file. If I load this playlist into foobar, it will load all the playlist items, but there is not artist/track information, just a long URL. If I start to stream the song, it won't reveal the artist/track at all. Is anyone else experiencing this problem? Should I be able to see the song information? Song information shows up with External player, but I'd like to control the music from inside foobar. Thanks.
eli2k
Postby aplus01 » Thu Apr 15, 2010 1:56 pm
I'm running into the same issue. I'm running portable foobar2K v1.0. Did you ever find a fix for this?
aplus01
Postby eli2k » Thu Apr 15, 2010 5:48 pm
Nah, no response from anybody, yet.
eli2k
Postby aplus01 » Mon May 10, 2010 12:36 pm
have you had any luck getting this resolved?
on a whim i decided to try a portable version of winamp to see if it fared any better than foobar. tried out winamp 5.572 and i get a playlist that is legible until the track starts playing at which point the track info is replaced with:
stream?player=3&pathUtf8Hex=4...
its weird that it loads correctly at first.
aplus01
Postby aplus01 » Mon May 10, 2010 2:04 pm
Looks like the issue is with the way LAME encoder is being called to down sample. When I turn off down sampling (i.e. set max bitrate to "No Limit") things run as expected and tags are displayed correctly.
Sindre - can you add the necessary info to the call to LAME when down sampling?
Found the switches to use on the sourceforge page for LAME:
ID3 tagging:
--tt <title> audio/song title (max 30 chars for version 1 tag)
--ta <artist> audio/song artist (max 30 chars for version 1 tag)
--tl <album> audio/song album (max 30 chars for version 1 tag)
I'll start a post under feature requests too and consider this one kaput.
aplus01
Postby Palmski » Fri Jul 09, 2010 8:34 am
I have the same problem but max bitrate is set to "No Limit".
I also have "Player has dynamic IP" and "Control player automatically" set for what it's worth.
Anyone know what the problem might be?
Palmski
Postby aplus01 » Wed Jul 14, 2010 12:12 pm
@Palmski - Yeah, the issue is with the LAME encoder. Subsonic isn't requesting the LAME encoder to provide the Title & Artist info.
Sounds like you aren't downsampling but maybe converting from one format to another which would use the LAME encoder.
I opened a feature request for it since its nice to know what you're listening to. Sindre indicated it was in the long list-o-things he was working on it.
Here's the feature request if you're interested
aplus01
Postby Palmski » Thu Jul 15, 2010 11:12 pm
Ah thanks, that's likely it - I do have quite a few m4a files thanks to iTunes. Should have remembered the transcoding....
At least it's good to know what the problem is so I don't spend hours trying to figure out a way of fixing it.
Palmski
