Help recovering admin password
Postby bianini » Wed Apr 14, 2010 11:38 am
I've installed subsonic a while ago. I have build 3.6 installed using Apache version.
I've created both a login for me and my wife but without admin privileges. Since all this time past I forgot the admin login and password. Is there a way to recover it without having to reinstall it?
Thanks in advance
bianini
Postby bianini » Tue Apr 20, 2010 9:39 am
Sorry, but I can't solve this. Can somebody help me?
bianini
Postby rob42 » Tue Apr 20, 2010 7:25 pm
If you are on Linux, have a look in
/var/subsonic/db/subsonic.script
(no idea where this file is on Windows). In this (text) file you'll find a line like
INSERT INTO USER VALUES('admin','enc:6162636465',7092064514,0,0,FALSE)
The password is the string after "enc:" in hexadecimal. So grab an ASCII table and decode :) In this example it's "abcde".
rob42
Postby bianini » Tue Apr 20, 2010 7:35 pm
Thank you very much!!
In Windows the folder is similar
C:\subsonic\db\subsonic.script
I've found the line and decode it with an Hex/Ascii converter:
http://www.dolcevie.com/js/converter.html
bianini
You're the best
Postby hgottfried » Tue Apr 20, 2010 10:11 pm
Thanks...got my logon working too
hgottfried
I had the same problem and want to thank all
Postby mzcl-mn » Sat Nov 27, 2010 6:52 pm
Hello to all who posted here.
Special compliments to those who contributed decisively to the solution: rob42 and bianini who took the time to add up a web address to simplify the conversion of the hex code.
I have a cloudy memory and forgot to annotate in a safe place the key to the admin account. Followed the directions and got it!
Thanks again and cheers!
Courage is the key to unleash happiness
mzcl-mn
Re: Help recovering admin password
Postby FairBolFL » Tue Jun 12, 2012 3:57 pm
OK, I'm having trouble retrieving/resetting my password.....for some reason, I'm putting in what I think is the right password on the login page, but it won't take. UPDATE: Now I can't even get to the localhost page, Firefox says it can't find the page. What's going on? I'm trying to run Subsonic on Windows 7.
FairBolFL
Postby lafoirefouille » Mon May 13, 2013 9:33 am
rob42 wrote:If you are on Linux, have a look in
Password are not encrypted in the database, it is a big security issue
Is there a way to have it securely stored ?
lafoirefouille
Postby rackserver » Wed Feb 14, 2018 3:38 pm
I have my hard drive encrypted. So the stored passwords are not accessible.
Windows and Mac have free solutions. I use Very Crypt because i don't trust Mac and Windows.
rackserver
Postby ronaldk » Wed Mar 21, 2018 10:03 am
Is there also a way, to get your login pasword? Every emailadress I use it says 'sorry user not found'
ronaldk
Postby laetoli » Mon Dec 21, 2020 5:45 pm
The default admin password is admin. What I did is uninstall Subsonic, deleted the c:\Subsonic folder, reinstalled Subsonic and then the admin password was reset to "admin"
laetoli
Users browsing this forum: No registered users and 80 guests
