Cover Bug Subsonic 4 Beta
Postby deejay2302 » Sat Apr 24, 2010 5:57 pm
Hi Sindre. I have a problem with some CD covers. If the covers are slightly larger overlap and the "Change" button and I can not edit them. The problem is mainly about the cover, the A4 format. So long downward.
See screenshot:
Click to Full Screen.
21.681 Artists
58.141 Albums
674.091 Songs
5072,14 GB (~ 49.341 Hours)
deejay2302
Postby eli2k » Sat Apr 24, 2010 8:54 pm
I use the Tab key to move around the links on the page and get around this, and when you think it selects the Change URL, press enter.
eli2k
Postby deejay2302 » Sun Apr 25, 2010 1:49 pm
Ah ok it works. I must switch a long time but its a little bit ok. THX
21.681 Artists
58.141 Albums
674.091 Songs
deejay2302
Postby eli2k » Mon Apr 26, 2010 8:40 am
Shorcut - on a link 'nearby' the cover (if you are a web developer, then you should understand where I'm getting at) and then drag your mouse away so you don't actually select it, but the link is highlighted. Then you can Tab more quickly to the destination. :)
eli2k
