Java Out of Memory error...
Postby ponch_420 » Sat May 01, 2010 12:55 pm
Hello all I a N00b here and have installed the latest release 3.9 and got the following error i then installed the latest beta release on Windows 2008 R2 Standard with the most up to date Java application. This is the error I am receiving, any ideas on what is happening here?
Exception java.lang.OutOfMemoryError
Message Java heap space
Java version Sun Microsystems Inc. 1.6.0_20
Operating system Windows Server 2008 R2 6.1
Server jetty-6.1.x
Memory Used 96 of 96 MB
Stack trace java.lang.OutOfMemoryError: Java heap space
ponch_420
Increasing the maximum memory for the heap
Postby jeremyh » Fri May 07, 2010 8:11 pm
You just need to increase the maximum memory allowed for the heap in the startup script. On linux it is the tomcat startup script (/etc/init.d/tomcat6), but you will likely have something else on Windows (whatever hosts the subsonic instance).
I adjusted the line:
"JAVA_OPTS="-Djava.awt.headless=true -Xmx1024M"
the -Xmx switch specifies the maximum heap to allow for the process.
(you can also put in -Xms to adjust the initial heap size).
see http://forums.sun.com/thread.jspa?threadID=326216
jeremyh
Postby sindre_mehus » Sat May 08, 2010 6:36 am
On Windows, click the Subsonic tray icon, click Settings and adjust the memory limit. Try setting it to 150 MB.
