No web service started
Postby johngaltky » Tue May 04, 2010 5:04 pm
First let me say I that I have some experience with Subsonic 3.8 on my QNAP TS439. It works very well.
No I am needing to migrate to a Synology DS1010+. I have installed JRE and Subsonic 4.0 beta 1. Edited subsonic.sh and when I start the database is built but I can't access the local server on the port I specified in the subsonic.sh script.
Any ideas on what's going wrong?
The only warnings I get are below:
10066 [main] WARN org.mortbay.log - failed org.mortbay.jetty.nio.SelectChannelConnector$1@76458f
java.io.IOException: Function not implemented
   at sun.nio.ch.EPollArrayWrapper.epollCreate(Native Method)
   at sun.nio.ch.EPollArrayWrapper.<init>(EPollArrayWrapper.java:69)
   at sun.nio.ch.EPollSelectorImpl.<init>(EPollSelectorImpl.java:52)
   at sun.nio.ch.EPollSelectorProvider.openSelector(EPollSelectorProvider.java:18)
   at java.nio.channels.Selector.open(Selector.java:209)
   at org.mortbay.io.nio.SelectorManager$SelectSet.<init>(SelectorManager.java:279)
   at org.mortbay.io.nio.SelectorManager.doStart(SelectorManager.java:201)
   at org.mortbay.jetty.nio.SelectChannelConnector.doStart(SelectChannelConnector.java:308)
   at org.mortbay.jetty.Server.doStart(Server.java:228)
   at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:101)
   at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:58)
   at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
   at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
   at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
   at net.sourceforge.subsonic.booter.Main.<init>(Main.java:16)
   at net.sourceforge.subsonic.booter.Main.main(Main.java:24)
10070 [main] WARN org.mortbay.log - failed SelectChannelConnector@192.168.1.10:8070
10073 [main] WARN org.mortbay.log - failed Server@d0deb5
10195 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
10219 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
10312 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[192.168.1.10:9412](local),objID:[0:0:0, 0]]]]
johngaltky
Postby sindre_mehus » Tue May 04, 2010 7:42 pm
Sounds like a Java/OS issue. Try google "EPollArrayWrapper function not implemented".
Postby johngaltky » Tue May 04, 2010 8:15 pm
This explains it. Guess Subsonic won't work on Synology DS until they deliver a proper kernel.
johngaltky
