Connection failure. Didn't understand the reply...
Postby technic » Thu May 06, 2010 4:51 pm
Please check the server address.
Everything has been working fine until yesterday and now I keep getting this error. I haven't changed any settings. The only thing I've done differently is donate. Please help!
technic
Postby sindre_mehus » Thu May 06, 2010 6:32 pm
If you post or email me your subsonic.org address, I might be able to troubleshoot this.
Cheers,
I am having this same problem today.
Postby randregL » Thu May 06, 2010 11:11 pm
ERROR:
Either the Subsonic URL is incorrect, the Subsonic server is down, or you may be connected to Wifi but do not have acess to the outside Internet.
I have made no changes to any settings but have been getting this error message all day. I got this message when accessing over 3G; once I turned on the wifi on my iPhone, it connected with no problem.
When I'm logged into Subsonic and try to test the URL, I get this message:
regrandall.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException)
Again, this is only when I'm connecting via 3G.
my URL is http://regrandall.subsonic.org
randregL
Postby sindre_mehus » Fri May 07, 2010 1:48 pm
Are you using manual or automatic port forwarding? (Automatic as in "Settings > Network" in Subsonic).
If you're using manual port forwarding, to which IP address and port do you forward. (I would expect it to be 192.168.1.100 and port 80)
I'm using automatic port forwarding,
Postby randregL » Fri May 07, 2010 6:07 pm
Port 80 is forwarded to 192.168.1.100
I'm not sure why this quit working, it was working fine the day before. I haven't changed any of the settings.
randregL
Postby sindre_mehus » Fri May 07, 2010 6:36 pm
Does it work from a different computer on the same local network?
I can open it on my home computer via wifi.
Postby randregL » Sat May 08, 2010 2:12 am
However, I tried to open the site at work yesterday and couldn't get it to load.
randregL
I'm at a friend's house now
Postby randregL » Sat May 08, 2010 2:51 pm
and can't get it to load at all.
randregL
Kick for the hope that someone can help!
Postby randregL » Wed May 12, 2010 12:00 am
nt
randregL
