Anxst wrote:Okay, I nearly have everything I want working. The only remaining issue is my WMA Losless files. As far as I'm aware, ffmpeg does not support WMA lossless decoding.
I downloaded the Windows Codec pack you linked to, and attempted to use wmadec to do the decoding for me. As far as I'm aware, wmadec will output a PCM file that I'll need to transcode with LAME.
However, at this point all I get is static. If I set the wmadec decode to use only 8 bits per sample, I can hear the music, sped up as if being sung by the Chipmunks.
Here's what I'm doing:
wmadec -b 16 %s -
lame -b %b - -
Where's my error? Any thoughts?
BillLee3 wrote:I'm in the same boat. Tried adding a "-x" to end of lame command line and right after lame, but didn't work. I'm getting a
DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) Warning: unsupported audio format
on all .wma files if i use the "wmadec - b 16 %s -" command line you used. What am I doing wrong?
cbr:
wmadec -b 16 %s -
lame -b %b -r - -
or vbr:
wmadec -b 16 %s -
lame -v -b %b -r - -Users browsing this forum: No registered users and 11 guests
