CoverArtController Failed to create thumbnail for All
Postby zilfrid » Wed May 12, 2010 2:03 pm
Hello
I use subsonic on a new "FreeBSD Jail"
my folder music is : mount_nullfs -o ro
/media/usb/MUSIC on /jail/jail4/mnt (nullfs, local, read-only)
i'v only minimum package installed :
autoconf-2.62       Automatically configure source code on many Un*x platforms
autoconf-wrapper-20071109 Wrapper script for GNU autoconf
automake-1.10.1     GNU Standards-compliant Makefile generator (1.10)
automake-wrapper-20071109 Wrapper script for GNU automake
bigreqsproto-1.1.0  BigReqs extension headers
ccache-2.4_9        A tool to minimize the compile time of C/C++ programs
compat7x-i386-7.2.702000.200906.1 A convenience package to install the compat7x libraries
cups-client-1.4.3   Common UNIX Printing System: Library cups
db41-4.1.25_4       The Berkeley DB package, revision 4.1
desktop-file-utils-0.15_1 A couple of command line utilities for working with desktop
diablo-jdk-1.6.0.07.02_9 Java Development Kit 1.6.0_07.02
gamin-0.1.10_3      A file and directory monitoring system
gettext-0.17_1      GNU gettext package
gio-fam-backend-2.24.1 FAM backend for GLib's GIO library
glib-2.24.1         Some useful routines of C programming (current stable versi
gmake-3.81_3        GNU version of 'make' utility
gnutls-2.8.6        GNU Transport Layer Security library
help2man-1.38.2     Automatically generating simple manual pages from program o
inputproto-2.0      Input extension headers
javavmwrapper-2.3.4 Wrapper script for various Java Virtual Machines
jdk-1.6.0.3p4_15    Java Development Kit 1.6.0
kbproto-1.0.4       KB extension headers
libICE-1.0.6,1      Inter Client Exchange library for X11
libSM-1.1.1,1       Session Management library for X11
libX11-1.3.3,1      X11 library
libXau-1.0.5        Authentication Protocol library for X11
libXaw-1.0.7,1      X Athena Widgets library
libXdmcp-1.0.3      X Display Manager Control Protocol library
libXext-1.1.1,1     X11 Extension library
libXi-1.3,1         X Input extension library
libXmu-1.0.5,1      X Miscellaneous Utilities libraries
libXp-1.0.0,1       X print library
libXpm-3.5.7        X Pixmap library
libXt-1.0.7         X Toolkit library
libXtst-1.1.0       X Test extension
libcheck-0.9.8      A unit test framework for C
libgcrypt-1.4.5     General purpose crypto library based on code used in GnuPG
libgpg-error-1.7    Common error values for all GnuPG components
libiconv-1.13.1_1   A character set conversion library
libpthread-stubs-0.3_3 This library provides weak aliases for pthread functions
libsigsegv-2.5      Handling page faults in user mode
libtool-2.2.6b      Generic shared library support script
libxcb-1.5          The X protocol C-language Binding (XCB) library
libxml2-2.7.7       XML parser library for GNOME
libxslt-1.1.26      The XSLT C library for GNOME
m4-1.4.14,1         GNU m4
m4-1.4.14,1         GNU m4
mysql-client-5.1.46 Multithreaded SQL database (client)
open-motif-2.2.3_6  Motif X11 Toolkit (industry standard GUI (IEEE 1295))
p5-gettext-1.05_2   Message handling functions
pcre-8.02           Perl Compatible Regular Expressions library
perl-threaded-5.10.1 Practical Extraction and Report Language
pkg-config-0.23_1   A utility to retrieve information about installed libraries
portupgrade-2.4.6_4,2 FreeBSD ports/packages administration and management tool s
printproto-1.0.4    Print extension headers
python26-2.6.4      An interpreted object-oriented programming language
recordproto-1.14    RECORD extension headers
ruby-1.8.7.248_2,1  An object-oriented interpreted scripting language
ruby18-bdb-0.6.5_1  Ruby interface to Sleepycat's Berkeley DB revision 2 or lat
servlet-api-2.5_3   The Servlet API
tomcat-6.0.26       Open-source Java web server by Apache, 6.x branch
unzip-6.0           List, test and extract compressed files in a ZIP archive
xbitmaps-1.1.0      X.Org bitmaps data
xcb-proto-1.6       The X protocol C-language Binding (XCB) protocol
xcmiscproto-1.2.0   XCMisc extension headers
xextproto-7.1.1     XExt extension headers
xf86bigfontproto-1.2.0 XFree86-Bigfont extension headers
xorg-macros-1.6.0   X.Org development aclocal macros
xproto-7.0.16       X11 protocol headers
xtrans-1.2.5        Abstract network code for X
zip-3.0             Create/update ZIP files compatible with pkzip
12/05/10 17:52:48 RET] WARN CoverArtController Failed to create thumbnail for /mnt/Horace Andy/Horace Andy - Living In The Flood/folder.jpg
[12/05/10 17:52:48 RET] WARN CoverArtController Failed to create thumbnail for /mnt/Horace Andy/Horace Andy - Skylarking/folder.jpg
[12/05/10 17:52:48 RET] WARN CoverArtController Failed to create thumbnail for /mnt/Horace Andy/Horace Andy - Livin It Up/folder.jpg
[12/05/10 17:52:49 RET] WARN CoverArtController Failed to create thumbnail for /mnt/Horace Andy/info.jpg
[12/05/10 17:41:31 RET] WARN CoverArtController Failed to create thumbnail for /mnt/AC-DC/AC-DC - Back In Black/folder.jpg
[12/05/10 17:41:31 RET] WARN CoverArtController Failed to create thumbnail for /mnt/AC-DC/AC-DC - Black Ice/folder.jpg
[12/05/10 17:41:31 RET] WARN CoverArtController Failed to create thumbnail for /mnt/AC-DC/AC-DC - Dirty Deeds Done Dirt Cheap/folder.jpg
[12/05/10 17:41:31 RET] WARN CoverArtController Failed to create thumbnail for /mnt/AC-DC/AC-DC - High Voltage/folder.jpg
[12/05/10 17:41:31 RET] WARN CoverArtController Failed to create thumbnail for /mnt/AC-DC/AC-DC - If You Want Blood/folder.jpg
[12/05/10 17:41:31 RET] WARN CoverArtController Failed to create thumbnail for /mnt/AC-DC/AC-DC - Highway to Hell/folder.jpg
[12/05/10 17:41:31 RET] WARN CoverArtController Failed to create thumbnail for /mnt/AC-DC/AC-DC - Powerage/folder.jpg
[12/05/10 17:41:31 RET] WARN CoverArtController Failed to create thumbnail for /mnt/AC-DC/info.jpg
[12/05/10 17:41:31 RET] WARN CoverArtController Failed to create thumbnail for /mnt/AC-DC/AC-DC - TNT/folder.jpg
[12/05/10 17:41:51 RET] WARN CoverArtController Failed to create thumbnail for /mnt/Babylon Circus/Babylon Circus - Dances of Resistance/folder.jpg
[12/05/10 17:41:51 RET] WARN CoverArtController Failed to create thumbnail for /mnt/Babylon Circus/Babylon Circus - Au Marche Des Illusions/folder.jpg
[12/05/10 17:41:56 RET] WARN CoverArtController Failed to create thumbnail for /mnt/Babylon Circus/Babylon Circus - Au Marche Des Illusions/folder.jpg
Does i need to change my chmod Folder "750" / items 640 ( track_N*.mp3 folder.jpg)?
Does i need to install:
    ImageMagick-nox11-6cups-image-1.4.3 Common UNIX Printing System: Library cupsimage
    jbigkit-1.6 Lossless compression for bi-level images such as scanned pa
    libfpx-1.2.0.12_1 Library routines for working with Flashpix images
    png-1.4.1_1 Library for manipulating PNG images
    tiff-3.9.2_1 Tools and library routines for working with TIFF imag
    or something else?
zilfrid
Postby sindre_mehus » Wed May 12, 2010 2:04 pm
Please find more error details in /var/subsonic/subsonic.log
Postby zilfrid » Wed May 12, 2010 2:13 pm
sindre_mehus wrote:Please find more error details in /var/subsonic/subsonic.log
thank you
Sorry for my english ...
here an extrait of my log:
[2010-05-12 17:31:26,788] WARN CoverArtController - Failed to create thumbnail for /mnt/Alain Souchon/Alain Souchon - Ecoutez D'ou Ma Peine Vient/folder.jpg
java.lang.NoClassDefFoundError: Could not initialize class sun.awt.X11GraphicsEnvironment
        at java.lang.Class.forName0(Native Method)
        at java.lang.Class.forName(Class.java:169)
        at java.awt.GraphicsEnvironment.getLocalGraphicsEnvironment(GraphicsEnvironment.java:68)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
        at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:852)
        at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
        at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
        at java.lang.Thread.run(Thread.java:619)
[2010-05-12 17:54:56,990] INFO PlaylistInputStream - markuss listening to "Babylon Circus - Au Marche Des Illusions/04 - Casse La Fatigue.mp3"
[2010-05-12 17:58:42,219] INFO PlaylistInputStream - markuss listening to "Babylon Circus - Au Marche Des Illusions/05 - Paul.mp3"
[2010-05-12 18:03:30,775] INFO PlaylistInputStream - markuss listening to "Babylon Circus - Au Marche Des Illusions/06 - Lorenzo.mp3"
[2010-05-12 18:09:23,143] INFO PlaylistInputStream - markuss listening to "Babylon Circus - Au Marche Des Illusions/07 - Yakaf Okon.mp3"
[/code]
zilfrid
resolv
Postby zilfrid » Thu May 13, 2010 1:06 am
I have do nothing else (just reboot tomcat server) :D
Today any thumbnails are good
zilfrid
Users browsing this forum: No registered users and 44 guests
