Subsonic Setup in Android Device
Postby usindians » Fri May 14, 2010 4:25 am
Hi
I have Subsonic 4.0 (on my desktop) configured to run on port 444 since my service provider blocks port 80.
I recently purchased HTC Incredible (Android 2.1) device and downloaded subsonic from Android Market. As part of setting up my device I am giving my url in the setup window with my port for ex: http://XXXX.XXXX.com:444/ (I presume the device app is expecting to connect using port 80?) for it returns with an error. This same URL works from a laptop when I connect from internet.
I also tried to create another domain using DYNDNS and used webhop feature of DYNDNS to redirect this new address to my subsonic server but without any luck. Is there anything I can do to make this connection from my Android device to my subsonic server? Any advice will greatly help.
thanks
Usindian
usindians
Postby anitract » Mon May 24, 2010 3:25 pm
Hello. First off, can you browse to your subsonic address via a web browser on a PC? If not, you have issues with your subsonic installation on your server.
Secondly, I believe you need to use the full address of your subsonic server in your droid app settings, so that would be http://XXXX.XXXX.com:444/subsonic/
...note the inclusion of the /subsonic/
anitract
