Subsonic on iPad
Subsonic on iPad
Postby Lutrae » Fri May 14, 2010 6:09 am
Hey there,
I was curious if there's a way to get HTML5 to function as the player, so that the iPad can run the browser? Is there a third party mod to enable this?
Lutrae
Postby eli2k » Sat May 15, 2010 10:17 am
There are iphone apps that interact w/Subsonic. Check them out on the frontpage somewhere. That should work with the ipad.
eli2k
in HTML5
Postby aktiveradio » Wed Aug 11, 2010 3:03 am
Ok I have the same question and that didn't get answered, anyone think they can do this in HTML5 so there is no need for the flash player?
if there is a Developer out there that would like to try this let me know.
aktiveradio
Postby mattgoldspink » Wed Aug 11, 2010 12:16 pm
Yep, my frontend here does it: http://forum.subsonic.org/forum/viewtopic.php?t=3747
It's not ready yet but should be released soon. It autodetects HTML5 Audio and then fails back to Flash (to be honest I can't claim the credit for that the soundmanager 2 library it uses does that for me)
mattgoldspink
Postby mattgoldspink » Wed Aug 11, 2010 12:29 pm
I should add, that I haven't tested it on the ipad since I don't own one. If someone buys me one I'll happily test it and get it working :D
mattgoldspink
Postby aktiveradio » Wed Aug 11, 2010 1:23 pm
Very cool front end and that fact it can do HTML5 with flash fallback even cooler.
I'd like to test it out, I have a iPad to test with as well as a Touch and iPhone.
Do you plan to release the front end you have built?
J.
aktiveradio
Postby mattgoldspink » Wed Aug 11, 2010 3:17 pm
Yep I plan to release it in the next few weeks. I'm road testing it every day and tweaking it. It's almost in a decent state to be used by others. I'll update the thread once it's ready
mattgoldspink
Postby mattgoldspink » Wed Aug 11, 2010 11:33 pm
So here's an initial drop of the code at the googlecode project: http://code.google.com/p/subtunes/
I haven't figured out an easy way to get it hooked into the windows installer, but if you're running with Apache on linux then it should be easy to follow the instructions to get it up and running. There are a few known issues but feel free to file suggestions and bugs on the site and I'll do my best to keep on top of them.
At the moment Chrome and Firefox are known to work. I've not tested with other browsers. I'd be interested to hear if people find bugs or confirm if it works out of the box.
To be honest I don't expect it to work on an ipad as touch events don't map to mouse click events. I'll see if I can make an ipad friendly version in the future.
Matt
mattgoldspink
Postby Kirk » Thu Aug 12, 2010 7:26 pm
As an iPad owner (who is currently typing this post on an iPad while streaming Subsonic with iSub) I would be thrilled to see an iPad specific application for Subsonic. :D
The UI of iSub is somewhat limited because it's designed for the iPhone.
But I don't anticipate one will be created anytime soon unless the web interface can be adapted to use HTML5. Even Facebook hasn't released a dedicated iPad app to date...
Cheers,
Kirk
Kirk
Postby mattgoldspink » Wed Dec 15, 2010 1:23 am
As promised here's an initial cut of an ipad compatible frontend: http://code.google.com/p/subtunes/downloads/detail?name=subtunes-0.9.zip
It is in a very beta state, so there are many bugs, but feel free to give it a try and give any feedback
mattgoldspink
Postby sokes » Thu Dec 16, 2010 4:00 pm
This is awesome thanks Matt + Josh!
Any plans to make an iphone compatible web-gui (not an app)?
Thanks for your hard work
sokes
Postby mattgoldspink » Thu Dec 16, 2010 9:15 pm
I do plan to, but not til after iPad version is complete and a fe of the desktop bugs have been fixed. I'll see what I can get done over Christmas holidays
mattgoldspink
Users browsing this forum: No registered users and 66 guests
