Web Interface not working
Postby starnix » Tue May 18, 2010 3:07 am
I am not sure if I am doing something wrong but when I try to access the web interface I get the following error:
(Error code: ssl_error_rx_record_too_long)
I am running the latest Ubuntu (10.04) with Subsonic 4.0.1. I have subsonic running on port 443 and am using "https://[myipaddress]:443. I have tried replacing the ip with localhost with the same result. Please help as I have purchased a license and cannot install it without getting to the web interface.
starnix
Postby burjast » Tue May 18, 2010 7:34 am
maybe, just maybe try to change <VirtualHost *> to <VirtualHost *:80> in config
if not, please be aware, that your problem relates to misconfigured apache, try to google the error, it is not related to subsonic
burjast
Postby starnix » Tue May 18, 2010 5:01 pm
Ok I must be missing something because nowhere in the installation directions did it mention having to install and configure apache. I just assumed subsonic had its own webserver. Is this not the case? To be honest, the only reason I am trying to bring it up is to enter the license #. Is there a different way of doing it? Editing a text file perhaps?
starnix
Postby eli2k » Wed May 19, 2010 5:37 am
Have you tried running it without SSL on a different port yet?
eli2k
Postby starnix » Thu May 20, 2010 2:51 pm
How do I disable SSL?
starnix
Postby precipitous » Fri May 21, 2010 7:14 am
starnix wrote:Ok I must be missing something because nowhere in the installation directions did it mention having to install and configure apache. I just assumed subsonic had its own webserver. Is this not the case? To be honest, the only reason I am trying to bring it up is to enter the license #. Is there a different way of doing it? Editing a text file perhaps?
You do not need to install or configure Apache in order to be able to run Subsonic. I have been running it on Ubuntu from Jaunty on (now it is on Lucid) without having to install any other servers.
precipitous
