Reverse Proxy settings om apache2 gives error using deb inst
Postby primary » Tue May 18, 2010 12:43 pm
I've installed a Ubuntu 10 server to run Subsonic.
I've been using the WAR install and tomcat, this has been working great.
I've been able to to use a reverse proxy setting that reroute
http://domain:port/subsonic/ to http://domain/subsonic/
This workes great and this is the way I would like to have it.
Using the deb installer web server is directed to only use port number and no /subsonic/
Open the Subsonic web page on http://localhost:4040 as stated on subsonic.org workes great.
Trying to setup reverse proxy just gives me errors. Any one successfully made reverse proxy work using deb installer?
proxy settings:
ProxyRequests Off
ProxyPreserveHost On
<Proxy *>
Order allow,deny
Allow from all
</Proxy>
ProxyPass /subsonic/ http://domain:port/subsonic/
ProxyPassReverse /subsonic/ http://domain:port/subsonic/
I've tried to remove /subsonic/ only using domain:port but still no luck.
Pleas help :)
primary
Problem is solved
Postby primary » Tue May 18, 2010 9:13 pm
Solution was to configure a new virtual server on apache, and point the server name to /var/subsonic and make a proxy redirect to internal server IP and port.
DocumentRoot "/var/subsonic"
ServerName subsonic.domain.com
ServerAlias subsonic*
ServerAlias www.subsonic*
<Directory "/var/subsonic">
allow from all
Options +Indexes
</Directory>
ProxyRequests Off
<Proxy *>
Order allow,deny
Allow from all
</Proxy>
ProxyPass / http://internalIP:8080/
( I've changed the port from default 4040 to 8080 )
primary
