New songs
New songs
Postby ddarrund » Fri May 21, 2010 5:29 pm
I just downloaded and successfully ran subsonic. Does subsonic automatically add new additional songs to the list if I add the songs manually to the folders?
ddarrund
Postby wiseadam » Fri May 21, 2010 9:07 pm
Yes it will usually add them to the list within say 30 seconds I've found, but they will not searchable until the search index has been updated either manually or automatically (default is everyday at 3am). In settings--search, you can click the Update search index now button to do it manually.
wiseadam
