User Statistics broke in version 4.0.1?
Postby mannkind » Thu May 27, 2010 11:30 pm
I recently upgraded to:
Version 4.0.1 (build 1524) – May 13, 2010
Server jetty-6.1.x, java 1.6.0_17, Linux (23.7 MB / 33.6 MB)
Since the upgrade the User Statistics are no longer showing any values for "Streamed" and the other categories are missing values or showing incorrect ones.
Is there anything that can be done to fix this. I am running subsonic on Fedora 11 ( Vortexbox ).
mannkind
Postby sindre_mehus » Mon May 31, 2010 8:08 am
There was a bug fixed in version 4 that caused the stream statistics to be way to high.
When installing 4.0, the stream statistics are automatically reset to zero. I thought this was better than showing wrong values.
Regards,
