Can't Access Music from 3G?
Postby dkaff » Tue Jun 01, 2010 5:56 pm
I just got subsonic running last night and noticed that it seemed to go offline a couple of times. When I got up this morning it seemed to be working again but now when i try to access my music from work all i get is a "either the subsonic URL is incorrect or you are connected to wifi but do not have internet access."
Does anyone have any suggestions on what might be causing this erratic behavior?
dkaff
You might check your UPnP settings.
Postby randregL » Fri Jun 04, 2010 12:09 am
I'm having the same problem, it worked perfectly for a couple of weeks and then I started getting that same message. I've not been able to get it to work again. Apparently UPnP is stubborn to get to work sometimes. (I'm not really a techie, I just know enough to be dangerous.)
randregL
Same problem here...
Postby dkaff » Fri Jun 04, 2010 1:59 am
I'm having the same problem. It worked at some point and then just completely stopped. I've tried everything and still no luck. I don't know why this should be so difficult to set up when I have several other programs that do it flawlessly, automatically.
dkaff
Postby einsteinx2 » Fri Jun 04, 2010 6:27 am
These problems are (almost) always related to port forwarding in some way or another. Every router is different and unfortunately some are easier to configure than others, and some support UPnP for auto-configuration while others don't. Also, sometimes the modem that your router plugs into is actually a router as well and requires additional configuration to get things working. Although, since both of you actually had it working at one point before it stopped that kind of rules that out.
I'm not sure how some other programs are able to automatically configure routers easier than Subsonic as I haven't developed any server side streaming applications myself, but I can do my best to work out the problems you're having and get you up and running again.
Shoot me an email at support@einsteinx2.com and I'll get you guys fixed up. Just email me your router and modem brands/models, and if you're comfortable with it, your subsonic URLs so that I can test directly myself. Also, the more info the better, so if you can include your local IP address of the computer with Subsonic on it, the port, what URL works inside your own network, what you've tried so far, basically any information you feel is pertinent. With a little troubleshooting and trial and error, we can get to the root cause and fix it for good. Some setups are more of a pain than others, but in the end there is no setup that Subsonic just can't work on at all. Sometimes it just takes a little finessing ;)
einsteinx2
