UPnP and Web Forward thinks the address is 127.0.0.1
Postby twiztar » Thu Jun 03, 2010 4:23 pm
OK, this puzzles me. I'm using a standalone installation on ubuntu LTS 10.04.
Both the port redirection (UPnP) and the web forward service thinks the ip address is 127.0.0.1, instead of the correct one, 192.168.1.100.
The only thing I can think is that I have several network cards, but eth1 (not eth0) is the one in use.
Sadly I don't understand java, so I can't really see where the logic fails.
I've also tried to specify --host=192.168.1.100 with the same result - e.g. subsonic using 127.0.0.1 instead.
Setting all the other interfaces to 'down' and restarting subsonic does not help.
twiztar
Postby oeh » Thu Jun 03, 2010 11:21 pm
as do I.
so I switched to DynDNS ;-}
guess there will come a fix in time.
one thing to remember is to specify the port eg. in your case:
http://192.168.1.100:4040
Regards
OEH ;-}
oeh
Postby twiztar » Fri Jun 04, 2010 6:50 am
oeh wrote:guess there will come a fix in time.
Lets hope so :-)
oeh wrote:one thing to remember is to specify the port eg. in your case:
Of course, locally and if I set up the port forwarding manually it works just fine :-)
Port forwarding I don't mind to fixing manually, but I do find the *.subsonic.org stuff very valuable and would love that it got fixed.
Another thing; I switched main interface (from wlan1 to eth1 - wireless really sucks on servers (= ) about a week ago and it worked prior to the switch. Does subsonic save this sort of info anywhere?
twiztar
Postby twiztar » Tue Jun 08, 2010 12:04 pm
A shameless bump so that it catches Sindres attention :-)
twiztar
Postby oeh » Tue Jun 08, 2010 5:05 pm
twiztar wrote:A shameless bump so that it catches Sindres attention :-)
HI.
All in it's time, this error most certainly get the attention it deserves.
Have in mind that Sindre actually has a normal day job as well ;-}
Regards
OEH ;-}
oeh
Re: UPnP and Web Forward thinks the address is 127.0.0.1
Postby orangeshasta » Tue Sep 23, 2014 3:01 pm
Sorry to bump an old thread, but it appears that this bug still exists. I just installed on Ubuntu 14.04 and had Subsonic automatically configure my router with UPnP - and it appears that my router was instructed to forward the port to itself (127.0.1.1:4040). So, trying to access my server remotely using my *.subsonic.org address does not work if I'm using UPnP. Using manual port forwarding, it works just fine.
Worth noting is that I am coming from a Windows 7 installation that was working properly, and that all other threads I have seen which mention this problem are from people running on Ubuntu. This seems like it should be a pretty minor fix, hopefully we can get this addressed!
orangeshasta
Users browsing this forum: Google [Bot] and 21 guests
