JAVA error - browser failure
Postby lpadron » Thu Jun 03, 2010 6:06 pm
Have been using Subsonic for several days. Based it on a VISTA (fully updated) 4gb HP laptop. Everything more or less worked correctly until this morning.
Received the following JAVA MEMORY error (below) when starting the browser (tried both Chrome and IE 7). The browser locks up and never finishing populating the UI.
Tried reinstalling Subsonic. Tried reinstalling JAVA. Nothing works. Here's the error:
Exception java.lang.OutOfMemoryError
Message Java heap space
Java version Sun Microsystems Inc. 1.6.0_20
Operating system Windows Vista 6.0
Server jetty-6.1.x
Memory Used 96 of 96 MB
Stack trace java.lang.OutOfMemoryError: Java heap space
at java.util.regex.Pattern$BnM.optimize(Unknown Source)
at java.util.regex.Pattern.compile(Unknown Source)
at java.util.regex.Pattern.(Unknown Source)
at java.lang.String.split(Unknown Source)
at net.sourceforge.subsonic.service.SearchService$Line.parse(SearchService.java:724)
at net.sourceforge.subsonic.service.SearchService.getIndex(SearchService.java:602)
at net.sourceforge.subsonic.service.SearchService.getRandomAlbums(SearchService.java:481)
at net.sourceforge.subsonic.controller.HomeController.getRandom(HomeController.java:167)
at net.sourceforge.subsonic.controller.HomeController.handleRequestInternal(HomeController.java:95)
at org.mortbay.servlet.UserAgentFilter.doFilter(UserAgentFilter.java:81)
at org.mortbay.servlet.GzipFilter.doFilter(GzipFilter.java:132)
lpadron
Re: JAVA error - browser failure
Postby Gonzo » Thu Jun 03, 2010 6:12 pm
lpadron wrote:Memory Used 96 of 96 MB
Assign more memory to your subsonic. You should be able to change the basic settings from your windows start menu (Windows Installation Instructions)
After that, you'll have to restart your Subsonic.
Gonzo
more memory to a service?
Postby lpadron » Thu Jun 03, 2010 6:54 pm
Thanks Gonzo for the suggestion. How (step by step) do I assign more memory to a service? I've gone into properties for the SUBSONIC service. Don't see a way to assign more memory to a service from properties.
lpadron
Memory available - page file
Postby lpadron » Thu Jun 03, 2010 7:58 pm
FYI . . . total memory is 4gb - OS is 64 bit Vista - Page file is set to 6127mb.
lpadron
Re: more memory to a service?
Postby Luterin » Thu Jun 03, 2010 8:21 pm
lpadron wrote:Thanks Gonzo for the suggestion. How (step by step) do I assign more memory to a service? I've gone into properties for the SUBSONIC service. Don't see a way to assign more memory to a service from properties.
Click the Subsonic icon in the tray, then click the "settings" tab, change the field "Memory Limit", click "Save Settings". :)
Luterin
fixed!!!
Postby lpadron » Thu Jun 03, 2010 10:38 pm
Luterin, thanks!
Changed mem to 300 from 100. Fixed!!! Thanks.
BTW, Sindre. Subsonic is incredible. Love it!!! :)
Just wish there was a better abbreviation for Subsonic than "SS." Not a good thing especially considering history in Norway a few years back.
Thanks for all!!!
lpadron
