delete
delete
Postby bpm2000 » Fri Jun 04, 2010 5:48 pm
nm
bpm2000
Postby oeh » Fri Jun 04, 2010 6:00 pm
Ave you read the Getting started doku?
Have a search for portforwarding or similar search term.
This will give you some help in the right directions.
Regards
OEH ;-}
oeh
Postby bpm2000 » Fri Jun 04, 2010 8:18 pm
yes, getting started was the first thing I read ;) and I have searched, hence the detailed nature of my post.
I essentially cannot figure this out through cobbling pieces of other people's misfortunes together any longer.
bpm2000
Postby bpm2000 » Tue Jun 08, 2010 6:09 pm
well that was a waste of donation $.
GL other subsonic users.
bpm2000
Postby kermit22 » Fri Jun 11, 2010 8:37 pm
I hope you haven't given up yet. I'll try to help you out.
Just a warning that this is going to be a little complicated because of your current set up with 2 devices acting like routers but we should be able to get it figured out.
Two Questions
1. Is your Mac Mini connected wirelessly through your airport or is it plugged in? I'm not familiar with the port setup on these.
2. Can your Mac Mini be plugged directly into your WiMax router? It would be nice to eliminate one of your routers from the equation if it were possible with your current setup.
Let me know these answers and we can get started. :D
kermit22
Postby bpm2000 » Thu Aug 19, 2010 6:02 pm
I've changed routers since then - its an actiontec DSL modem/router now.
It is connected wirelessly and I do not have the option to plug it in directly.
I also have a new NAS now where all my media is stored, a Synology DS410J, if that makes thing any easier/more difficult. This is plugged directly into the modem/router at the moment but I am going to be changing that soon (plugging into mac mini directly and connecting wirelessly via router).
I have little hope that this will work but it would be nice.
thx
bpm2000
