Need help with setup- Mac Mini with Airport Extreme
Postby cchobo » Sun Jun 06, 2010 11:00 pm
Running Mac mini 10.6.3 with Airport Extreme network. I installed Subsonic and set up the admin account and music folder successfully. Then I attempted to configure the network settings.
Under Settings/Network, no router is found, so I attempted manual port forwarding. Under Airport Utility/Port Mapping I added a new item. There is a "Choose A Service" dropdown menu which I left alone. 5 fields are available to fill in- Public UDP Port, Public TCP Port, Private IP Address, Private UDP Port and Private TCP Port. I filled in the Private IP address with the Mini's stated IP of 10.1.3 from the System Prefs/Network window. I tried filling in the UDP and TCP fields with 4040, but the status on the Subsonic Settings/Network page always states "xxxx.subsonic.org is registered but could not connect to it."
Does anyone have any helpful advice? I purchased iSub, but it won't connect. Is there a way to connect using the direct numerical IP address which I use for other programs such as StreamToMe? Thanks very much.
cchobo
Resolved!
Postby cchobo » Sun Jun 06, 2010 11:17 pm
Filled in all TCP/UPD fields with 4040- then the xxx.subsonic.org address worked. In iSub, the :4040 address wouldn't work, but it worked with :80. I don't get it, but it worked!
cchobo
Postby dbasinger » Tue Jun 15, 2010 9:56 pm
I tried the steps that you did in AirPort Utility then when I tried to access my music on my Droid phone an error message that states "Connection Failure. No route to host" keeps popping up. Anybody have any ideas ?
I'm running a mac with the current software updates, an airport extreme and a Motorola Droid phone ...
dbasinger
I got it working on my Mac w/ Airport Extreme ...
Postby epstewart » Mon Jun 28, 2010 8:33 pm
I got it working on my Mac that has an Airport Extreme router. Here's how I did the port forwarding: I used Lighthouse (http://codelaide.com/blog/products/lighthouse)!
Lighthouse costs $12.99. That's in addition to the donation you make for Subsonic so it will remember your web address. (I donated 20 euros, which is a little over $25.)
I also got the iSub app for my iPhone for $4.99.
Lighthouse installs as an icon in your Mac's menu bar, under which you select Edit Port Mapping Profiles ...
That brings up a window in which you click + to add a profile to the list in the top part of the window. I called my new profile "Subsonic." I then selected it in the top part of the window and in the bottom part of the window I clicked + to add the details I wanted: public port = 4040; private port = 4040; type = TCP. Then I turned on the check mark for "Enable this profile," and I clicked the Start Profile button.
Doing so allows the Mac to support port forwarding for port 4040, which is the port that Subsonic's server application, running on the Mac, uses by default. (The Subsonic application has to be running on the Mac for this server to even exist.)
Note that using this Lighthouse method avoids my having to configure my AirPort Extreme router in any special way to permit port forwarding. There was no need to use AirPort Utility at all.
Note also that Subsonic's Network Settings page, as it appears in my web browser, does not confirm -- repeat, does not confirm -- that "Automatically configure your router to allow incoming connections to Subsonic (UPnP port forwarding)" is working. It instead shows "Status: No router found." A far as I can tell, this doesn't matter. I do have "Access your server over the Internet using an easy-to-remember address" checked in the same Network Settings page, and I used it to create the web address http://epstewart.subsonic.org/. That worked OK: "Status: epstewart.subsonic.org responded successfully."
When I go to my second Mac and enter that URL in Safari, it automagically gets changed to http://10.0.1.23:4040/index.view, where 10.0.1.23 is the IP address being used on my local network by my first Mac. That brings up the entire contents of my first Mac's iTunes Music folder -- the one I pointed Subsonic to in its Music Folders settings on the first Mac -- in the second Mac's browser window. I can then select any album, say, and play it from beginning to end ... indicating that Subsonic is working properly and the 4040 port address is being used properly on my first Mac (which, remember, is running the Subsonic app, which uses port address 4040, and is also running Lighthouse).
After confirming that all that was working, I installed the iSub app on my iPhone and tapped the gear icon at upper left of the iPhone screen when iSub was active to add a server: http://epstewart.subsonic.org, with my Subsonic user name and password as I had configured them in Subsonic's Settings: Users browser pane. (Notice that I did not add ":4040" at the end of the http://epstewart.subsonic.org Internet address.) Once I had entered the proper server information in iSub, I tapped that server item in iSub's server list and tapped "Make Default Server" in the Server Options dialog. I was told I had to quit and reopen iSub for this to take effect, so I did so. When I did, iSub opened with my entire iTunes Music collection from my first Mac and put it in view in iSub on the iPhone, and I was able to navigate to whatever song(s) I wanted to hear and play it/them!
So I learned two key things:
(1) Using Lighthouse on my main Mac means I didn't have to fool with AirPort Utility or change my AirPort Extreme's configuration in any way. (I assume this remains true if you have a router other than an AirPort Extreme, by the say.)
(2) Using Lighthouse meant that it doesn't matter that "Automatically configure your router to allow incoming connections to Subsonic (UPnP port forwarding)" seemingly isn't working in the Subsonic Network Settings browser pane, but instead shows "Status: No router found." This seems to be a byproduct of (1) above. Since the router has not been made port 4040-aware, it doesn't port forward 4040 to the Mac at all ... but Lighthouse running the Mac fixes it up so port 4040 actually works for purposes of Subsonic streaming of music to other devices such as an iPhone running iSub.
epstewart
Postby dbasinger » Wed Jun 30, 2010 10:59 pm
:D :D :D
You are awesome. Worked perfectly once I reset my router to it's factory settings.
But for some reason it doesn't work when my phone tries connecting to the server on my home Wi-Fi network. What could that be ?
dbasinger
Postby epstewart » Thu Jul 01, 2010 10:13 am
dbasinger wrote::D :D :D
dbasinger,
Can you give more details?
Did you use Lighthouse, as per my earlier post?
Are you still getting the error message that states "Connection Failure. No route to host" on your Droid phone? How do you have the phone set up? What software are you using to allow it to connect? (I'm using iSub on an iPhone, so I know very little about Droid phones.)
If you give me more details, I'll try to help you figure it out ...
epstewart
