SubSonic doesn't start up since upgraded from Vista to 7
Postby wallyboz » Tue Jun 08, 2010 6:33 am
Since upgraded to W7 Subsonic generates below error(s)
(sorry, it's quite extensive :oops: )
org.springframework.beans.factory.xml.XmlBeanDefinitionStoreException: Line 5 in XML document from class path resource [applicationContext-agent.xml] is invalid; nested exception is org.xml.sax.SAXParseException: cvc-elt.1: Cannot find the declaration of element 'beans'.
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:369)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:313)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:290)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:142)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:158)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:184)
at org.springframework.context.support.AbstractXmlApplicationContext.loadBeanDefinitions(AbstractXmlApplicationContext.java:112)
at org.springframework.context.support.AbstractXmlApplicationContext.loadBeanDefinitions(AbstractXmlApplicationContext.java:79)
at org.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java:97)
at org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory(AbstractApplicationContext.java:411)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:338)
at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:122)
at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:66)
at net.sourceforge.subsonic.booter.Main.<init>(Main.java:16)
at net.sourceforge.subsonic.booter.Main.main(Main.java:21)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher.main(Unknown Source)
Caused by: org.xml.sax.SAXParseException: cvc-elt.1: Cannot find the declaration of element 'beans'.
at org.apache.xerces.util.ErrorHandlerWrapper.createSAXParseException(Unknown Source)
at org.apache.xerces.util.ErrorHandlerWrapper.error(Unknown Source)
at org.apache.xerces.impl.XMLErrorReporter.reportError(Unknown Source)
at org.apache.xerces.impl.xs.XMLSchemaValidator.handleStartElement(Unknown Source)
at org.apache.xerces.impl.xs.XMLSchemaValidator.startElement(Unknown Source)
at org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanStartElement(Unknown Source)
at org.apache.xerces.impl.XMLNSDocumentScannerImpl$NSContentDispatcher.scanRootElementHook(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.DOMParser.parse(Unknown Source)
at org.apache.xerces.jaxp.DocumentBuilderImpl.parse(Unknown Source)
at org.springframework.beans.factory.xml.DefaultDocumentLoader.loadDocument(DefaultDocumentLoader.java:78)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:361)
... 20 more
wallyboz
Postby WildWalker » Tue Jun 08, 2010 9:02 am
The SpringFramework errors are related to Java, I am not a programmer so I am not sure how (I googled the org.springframework.beans.factory.xlm error) so you might want to ensure you have the latest Java.
I would ensure you have the latest Java and Flash installed and try again.
Alan.
WildWalker
Windows 7 ipconfig
Postby wallyboz » Wed Jun 09, 2010 5:53 am
The issue seemed to be caused by the ipconfig of the network card.
Windows 7 added a standard-gateway at 0.0.0.0 above the regular (192.168.1.1) when set to DHCP.
Only since I set the card to fixed ip, gateway and dns it seemed that the issue was solved, meaning that the addresses in the error-message above could be reached at the startup of Subsonic.
wallyboz
Postby WildWalker » Wed Jun 09, 2010 6:11 am
Is the Windows 7 box the Subsonic server, or the client?
WildWalker
Postby sindre_mehus » Wed Jun 09, 2010 6:27 am
What version of Subsonic is this? I think I remember I fixed this problem some time ago.
Bingo! That's it.
Postby wallyboz » Thu Jun 10, 2010 4:37 am
Sindre, you're absolutely right.
I completely forgot all about the fact that prior to my upgrade to W7 I restored a clean Vista (mid 2009) image that had a v3.0 version of Subsonic running.
It must be said that with that previous version under Vista I never experienced that issue, but then again there seem to be a lot of other unexpected (unpleasant) issues in W7 too.
Thanks for pointing me in the right direction.
wallyboz
Users browsing this forum: No registered users and 44 guests
