Android search displaying 20 songs
Postby Headcase_Fargone » Tue Jun 08, 2010 11:05 pm
I did a search and was unable to find anyone else posting about this particular issue, though it's sort of a difficult thing to search for.
In the Android app I've noticed that Search only displays 20 random results. So say I have 500 tracks from "The Cure" it will only ever display 20 in a search for "The Cure." Is this by design? The web GUI search functions perfectly, so I'm wondering if maybe this was intentional.
Anyway, outstanding app. If something like this is the only fault I can find that's a job well done.
Headcase_Fargone
Postby Headcase_Fargone » Tue Jun 15, 2010 6:00 pm
No one knows for certain? At this point I'm assuming it's designed to work this way.
Headcase_Fargone
Postby JMilesT » Thu Jun 17, 2010 6:36 pm
I'm using the application on my Motorola Droid, and I just noticed the same thing.
JMilesT
