Upgrade to latest 4.01 build and now Upnp broken
Postby sonicdivx » Wed Jun 09, 2010 6:31 pm
I just upgrade and now cannot reach the server externally.
the only thing I have not done yet is reboot the Verizon Fios router. Wanted to find out if there is anything else should do.
Also I notice when in Network settings when I check external UPNP option and hit save message comes up saying
'Failed to test web address. Permission denied: connect (SocketException) '
I do not have Easy Address checked. So there is an error there. Also this message appears
'This feature is available until July 9, 2010. After that you must donate to use it permanently. '
What does that correspond too.
sonicdivx
Postby neodawg » Wed Jun 09, 2010 6:58 pm
Check the subsonic service settings to make sure that its running on the proper port that you forwarded in your router.
When I upgraded it went back to port 80 or 4040, whichever it was it wasnt the port i have setup for it to run on.
Music Collection--
2,890 artists
8,253 albums
103,492 songs
640.11 GB
7,023 hours
neodawg
