Cover art issue
Cover art issue
Postby kaotic » Fri Jun 11, 2010 5:16 pm
I would say about 95% or more of my music has cover art within subsonic. I have gone through and ensure my music was embedded with cover art so that it would show up in subsonic. I have even tried to point to a URL for the images (just to see if it would work) and still regardless if they are embedded or pointed to a URL they will not show up in subsonic. Any help would be appreciated TIA!
kaotic
Postby kaotic » Mon Jun 14, 2010 4:49 pm
What I have discovered so far is that If I do not enable the cover art download, and either use Itunes/Media Monkey to get the cover art or go and find the art myself and put it in the folder then of the album/files then it is ok.
Seems a little cumbersome to me though to have to go through all that.
kaotic
Postby WildWalker » Tue Jun 15, 2010 9:10 am
I found that because I used Media Player to rip/name my music that the cover art was a small thumbnail.
Probably like most people, I had to go through every album and insert the cover art I wanted.
It took time, I just used to do 10 albums a day until it was done, but it meant that I had the correct cover art, of a quality that satisfied me.
Then I backed up all my music with the new cover art ;)
WildWalker
Postby kaotic » Tue Jun 15, 2010 6:37 pm
That is basically what I have done.
kaotic
