Having problems accessing my Subsonic
Postby burninice21 » Fri Jun 11, 2010 8:33 pm
Hey,
I just upgraded my Ubuntu from 9.10 server to 10.04 server and then decided to upgrade Subsonic as well, however when I tried updating it and installing it it didnt work.
I was using the WAR installation so I deleted the /work and /subsonic folders. I haven't changed tomcat at all.
I think that part of the problem is giving permissions to tomcat6, I believe I did it but have no way of confirming that I did.
I get this error when trying to access localhost:8080/subsonic
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
java.io.FileNotFoundException: /var/lib/tomcat6/work/Catalina/localhost/subsonic/org/apache/jsp/WEB_002dINF/jsp/login_jsp.java (No such file or directory)
   java.io.FileOutputStream.open(Native Method)
   java.io.FileOutputStream.<init>(FileOutputStream.java:179)
   java.io.FileOutputStream.<init>(FileOutputStream.java:70)
   org.apache.jasper.compiler.Compiler.setupContextWriter(Compiler.java:276)
   org.apache.jasper.compiler.Compiler.generateJava(Compiler.java:215)
   org.apache.jasper.compiler.Compiler.compile(Compiler.java:332)
   org.apache.jasper.compiler.Compiler.compile(Compiler.java:312)
   org.apache.jasper.compiler.Compiler.compile(Compiler.java:299)
   org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:589)
   org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:317)
   org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:313)
   org.apache.jasper.servlet.JspServlet.service(JspServlet.java:260)
   javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
   org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:236)
   org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:257)
   org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1183)
   org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:902)
   org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:807)
   org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
   org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
   javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
   org.mortbay.servlet.UserAgentFilter.doFilter(UserAgentFilter.java:81)
   org.mortbay.servlet.GzipFilter.doFilter(GzipFilter.java:132)
   org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
   org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
   org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
   org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
   org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:166)
   org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
   org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:135)
   org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
   org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:173)
   org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:271)
   org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:110)
   org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
   org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
   org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
   net.sourceforge.subsonic.filter.RequestEncodingFilter.doFilter(RequestEncodingFilter.java:43)
   net.sourceforge.subsonic.filter.ParameterDecodingFilter.doFilter(ParameterDecodingFilter.java:54)
   net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:54)
note The full stack trace of the root cause is available in the Apache Tomcat/6.0.24 logs.
[/code]
burninice21
Users browsing this forum: No registered users and 44 guests
