Subsonic doesn't show folders with foreign characters
Postby karvanapa » Sun Jun 20, 2010 8:42 pm
Subsonic doesn't show folders with foreign characters. Song names are with characters like ä,ö and å are shown correctly.
I've installed Subsonic on Ubuntu with following information:
4.0.1 (build 1524)
jetty-6.1.x, java 1.6.0_0, Linux (48.0 MB / 56.1 MB)
I've found threads with similar problems but none of them seem to help. I think that the folder names in my music folder are not in UTF-8 because I've moved files and folders from my Windows machine using samba.
When I updated from 3.9 to 4.0 Subsonic indexed all folders, but after I restarted my Ubuntu machine this problem appeared again. Nothing seems to help...
karvanapa
Postby karvanapa » Mon Jun 21, 2010 7:33 pm
I noticed now that some of the files with foreign characters are shown correctly, but in some of them the characters are shown as � mark and subsonic wont play them.
I've tried to reinstalling subsonic and java-packages but no help. Doesn't anyone have any ideas?
karvanapa
Postby ccandreva » Tue Jun 22, 2010 12:45 am
Make sure the LANG environment variable is set. With the standard Fedora packages it wasn't, and I had to add these lines to /etc/sysconfig/subsonic
LANG=en_US.UTF-8
LC_COLLATE=C
ccandreva
Postby karvanapa » Tue Jun 22, 2010 4:23 pm
It works now! I noticed that after restaring Subsonic folders started to work. I didn't notice it before because I didn't rebuild the index.
I tried putting these lines:
LANG=en_US.UTF-8
LC_COLLATE=C
into /etc/init.d/subsonic and /etc/default/subsonic but it didn't help.
Then I tried the same with:
export LC_CTYPE
LC_CTYPE=en_US.UTF-8
Everything started to work after I put these lines into /etc/default/subsonic.
Thank you for pointing me into to the right direction ccandreva!
karvanapa
Postby frason » Mon Jul 05, 2010 7:33 am
karvanapa wrote:It works now! I noticed that after restaring Subsonic folders started to work. I didn't notice it before because I didn't rebuild the index.
LANG=en_US.UTF-8
LC_COLLATE=C
export LC_CTYPE
Thanks, I added the lines you wrote to /etc/init.d/subsonic
Now it works fine. :)
frason
Postby krizze » Mon Jul 12, 2010 11:19 am
Thanks a bunch, stupid me started renaming files and stuff, now I don't have to anymore ;)
krizze
Postby jbaile38 » Wed Jul 21, 2010 10:47 am
Anyone know how you would you go about doing this with the standalone version running on linux?
jbaile38
Postby dimaj » Wed Jul 21, 2010 4:28 pm
I'm curious too...
Do we have to modify the .sh script?
Paid Subsonic Customer
http://blog.dimaj.net
dimaj
