Localhost doesn't allow me to login.
Postby Aggro » Tue Jun 22, 2010 2:28 am
I just started using Subsonic today, and I had it working great, and was very pleased with the program. Unfortunately, I had to do a system restore, and now, when I go to localhosts, Subsonic doesn't load.
Instead I get:
http://tinypic.com/r/1id8o4/6
If I change the directory, I get:
"HTTP ERROR: 404
NOT_FOUND
RequestURI=/wtfisthis
Powered by Jetty://"
I have NO IDEA what's going on. If anyone has any idea how to fix this, I will be extremely grateful.
Aggro
Postby delcypher » Tue Jun 22, 2010 10:13 am
What port did you start subsonic on? The default is 4040 but in the screenshot you've gone to http://localhost which uses port 80.
Try http://localhost:4040/
Although the fact you're seeing something when going to localhost:80 means that your machine has a server listening on port 80, whether or not its subsonic is something else.
If that doesn't help then try stopping subsonic (I can't tell you how to do this unless you tell me what platform and install of subsonic you are using).
Delete 'subsonic.log' in your subsonic directory. Then start subsonic again. If it doesn't work then post the contents of the 'subsonic.log' file on the forum and we can take a look and see if it reports any obvious problems.
delcypher
Same issue here
Postby jasonk » Wed Jun 23, 2010 6:20 pm
THIS IS DRIVING ME NUTS!!!!!!!! Please let me know if/when you get this resolved and I'll do the same for u.
Jay
mdjs090803@rcn.com
jasonk
Users browsing this forum: No registered users and 44 guests
