change music folder....
Postby dolled » Thu Jan 25, 2007 12:33 am
Hi I have changed the drive on the server where the music is from d: to e:, but I can not find the place in Subsonic to set it......
dolled
Postby sindre_mehus » Thu Jan 25, 2007 12:56 am
You must be logged in as a user with administrative rights (for instance the user 'admin'). Then go to Settings > Music Folders.
Postby dolled » Thu Jan 25, 2007 11:26 pm
I first installed subsonic when you used username and pwd in a file. The user I am using should have admin rights, but I do not have the Music Folders under settings. Neither can I log on as admin (at least not with the pwd's I set it to in a earlier version. I also tried usr: admin pwd:admin). Is there any other way?
dolled
Postby dolled » Thu Jan 25, 2007 11:30 pm
I also remember in an earlier version I could set up many music folders, but not anymore. The version I am running is: 2.9 (build 371)
dolled
Postby mistaox » Wed Feb 14, 2007 8:03 pm
dolled wrote:I also remember in an earlier version I could set up many music folders, but not anymore. The version I am running is: 2.9 (build 371)
I have the same version. Log in as the admin and click on settings.
mistaox
