Installing Windows version on a drive other than C: = ERROR
Postby PnoT » Thu Jul 01, 2010 5:10 pm
My windows drive is F: instead of the usual C: and upon installing Subsonic it fails because it's trying to write files/folders to the c:\subsonic folder.
I tried to trick the app and just did a subst c: f:\ and that seemed to work in getting past the install but upon running the service i get this error:
java.lang.illegalargumentexception: bad temp directory: c:\subsonic\jetty\1529
I was able to work around this buy directly running the subsonic-booter-jar-with-dependencies.jar file but it ignores the preferences I have setup such as the port.
How can i get this thing to install properly?
PnoT
Postby oeh » Thu Jul 01, 2010 5:35 pm
Hi.
First of all. this topic are covered in numerous other posts on this forum.
So before posting a new topic, do a search on the forum.
One of the other posts regarding this theme you find here:
http://forum.subsonic.org/forum/viewtopic.php?t=3329&highlight=installing+windows+drive
Regards
OEH ;-}
oeh
