Port 80 in use error
Postby piscotikus » Sun Jul 04, 2010 2:43 pm
I installed fine, but get an error stating that port 80 is in use.
Is there a way around this? Or, what other port can I use?
piscotikus
Postby piscotikus » Sun Jul 04, 2010 2:44 pm
Sorry, I'm using Windows XP.
piscotikus
Postby delcypher » Sun Jul 04, 2010 4:03 pm
Why do you have port 80 in use? Are you intentionally running a webserver on your machine?
If you don't think you're running a webserver on your computer then you should look into why port 80 is in use.
You can use any port you like really as long as it doesn't conflict with a port on your system. Port 4040 seems to be the default choice for subsonic.
I would avoid trying to use a port that is traditionally used for another service see
http://en.wikipedia.org/wiki/List_of_TCP_and_UDP_port_numbers
delcypher
Postby piscotikus » Sun Jul 04, 2010 10:10 pm
I've done nothing special that I'm aware of. It says "Address already in use". Who knows why.
piscotikus
