MPC Transcoding error
Postby Stab » Wed Jul 07, 2010 10:36 am
Hello, I am running the latest version of subsonic on freenas 0.7.
Everythinks works fine except transcoding of mpc files :
I put the mppdec under /var/subsonic/transcode, set mppdec %s - in step1 and lame -b %b - -in step2 in the transcoding settings section.
When I try to play an mpc files, it plays then stops after 2 seconds...
I can see this in the log file :
[2010-07-07 10:23:15,602] INFO PlaylistInputStream - popol listening to "Le Tigre - Le Tigre/01 - Deceptacon.mpc"
[2010-07-07 10:23:15,624] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/mppdec] [/mnt/music2/L/Le Tigre/Le Tigre - Le Tigre/01 - Deceptacon.mpc] [-]
[2010-07-07 10:23:15,658] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/lame] [-b] [128] [-] [-]
[2010-07-07 10:23:15,670] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/mppdec)
[2010-07-07 10:23:15,671] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/mppdec)
[2010-07-07 10:23:15,671] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/mppdec) MPC Decoder  SV7  1.15v  3DNow/SSE   (C) 1999-2003 Buschmann/Klemm/Piecha/Wolf
[2010-07-07 10:23:15,689] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/mppdec)
[2010-07-07 10:23:15,690] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/mppdec)
[2010-07-07 10:23:15,719] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/mppdec) decoding of file '/mnt/music2/L/Le Tigre/Le Tigre - Le Tigre/01 - Deceptacon.mpc'
[2010-07-07 10:23:15,720] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/mppdec)          to <stdout>
[2010-07-07 10:23:15,727] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/mppdec)
[2010-07-07 10:23:15,728] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/mppdec)          Le Tigre: Le Tigre    (Rock, 1999)
[2010-07-07 10:23:15,728] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/mppdec)     [01] Deceptacon  (EAC secure - ripped by ROYDOG for PAD Crew)
[2010-07-07 10:23:15,728] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/mppdec)   222.2 kbps,    3:04.55, SV 7.0, Profile 'Insane' (Beta 1.14)
[2010-07-07 10:23:15,732] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/mppdec)
[2010-07-07 10:23:15,747] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) LAME: Can't get "TERM" environment string.
[2010-07-07 10:23:15,748] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) LAME 3.97 32bits (http://www.mp3dev.org/)
[2010-07-07 10:23:15,748] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) CPU features: MMX (ASM used), 3DNow! (ASM used), SSE
[2010-07-07 10:23:15,748] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) Using polyphase lowpass filter, transition band: 16538 Hz - 17071 Hz
[2010-07-07 10:23:15,748] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) Encoding <stdin> to <stdout>
[2010-07-07 10:23:15,748] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) Encoding as 44.1 kHz 128 kbps j-stereo MPEG-1 Layer III (11x) qval=3
[2010-07-07 10:23:16,017] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/mppdec)      0:00.01/    3:04.55 decoded ( 0.0%)
[2010-07-07 10:23:17,029] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/mppdec)      0:03.41/    3:04.55 decoded ( 1.8%)
[2010-07-07 10:23:18,012] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/mppdec)      0:13.83/    3:04.55 decoded ( 7.5%)
[2010-07-07 10:23:18,369] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/mppdec)      0:23.10/    3:04.55 decoded (12.5%)
Any ideas ???
I am not comfortable with transcoding ! :oops:
Stab
Postby delcypher » Wed Jul 07, 2010 11:20 pm
Can you test if your transcoders are capable of working without subsonic.
Try the following command (all one line):
/var/subsonic/transcode/mppdec '/mnt/music2/L/Le Tigre/Le Tigre - Le Tigre/01 - Deceptacon.mpc' - | /var/subsonic/transcode/lame -b 128k - > test.mp3
If this doesn't work (assuming I've typed in everything correctly) then your problem is the transcoding setup.
I don't have the program mppdec on my machine so I can't check if I've got the options correct. Are you sure that mppdec outputs the right type of wav file?
Why aren't you using ffmpeg to decode the mpc file to wav then passing that on to lame?
delcypher
Postby Stab » Thu Jul 08, 2010 9:17 am
Hi and thanks for your answer !
I tried the command you gave me and it works, i got a test.mp3 file at 128kb/s.
So I think it's not a transcoding issue, the problem is that when I try to play this file in subsonic, it plays 1 or 2 second then stops... :(
I wasn't using ffmpeg because i didn'it know it was able to decode mpc files !
Any ideas ? Does somebody had the same issue playing mpc files ?
Thanks again
Stab
Postby delcypher » Thu Jul 08, 2010 9:35 am
Is there anymore to your log file because there's nothing to indicate that the transcode failed.
Can you see if works if you use ffmpeg instead (see the wiki http://sourceforge.net/apps/mediawiki/subsonic/index.php?title=Transcoders)?
Ffmpeg supports every format under the sun! Run
ffmpeg -formats
or
ffmpeg -codecs
to see what your build of ffmpeg supports.[/code]
delcypher
Postby Stab » Thu Jul 08, 2010 10:59 am
Using ffmpeg, it's the same issue : the song starts playing, then stops after 1 second.
Here's the content of subsonic.log :
[2010-07-08 10:51:30,241] INFO PlaylistInputStream - popol listening to "Le Tigre - Le Tigre/01 - Deceptacon.mpc"
[2010-07-08 10:51:30,255] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/mnt/music2/L/Le Tigre/Le Tigre - Le Tigre/01 - Deceptacon.mpc] [-f] [wav] [-]
[2010-07-08 10:51:30,351] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/lame] [-q] [2] [--cbr] [-b] [128] [-] [-]
[2010-07-08 10:51:30,352] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) FFmpeg version 0.5, Copyright (c) 2000-2009 Fabrice Bellard, et al.
[2010-07-08 10:51:30,352] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   configuration: --prefix=/usr/local --mandir=/usr/local/man --enable-shared --enable-gpl --enable-swscale --enable-postproc --enable-avfilter --enable-avfilter-lavf --enable-pthreads --enable-memalign-hack --cc=cc --extra-cflags=-I/usr/local/include/vorbis -I/usr/local/include --extra-ldflags=-L/usr/local/lib  --extra-libs=-pthread --disable-debug --disable-sse --disable-mmx --disable-libamr-nb --disable-libamr-wb --disable-libdirac --disable-libfaac --enable-libfaad --enable-libfaadbin --disable-libgsm --disable-vhook --enable-ipv6 --disable-libmp3lame --disable-libopenjpeg --enable-libschroedinger --disable-ffplay --disable-libspeex --enable-libtheora --enable-libvorbis --disable-x11grab --enable-libx264 --enable-libxvid
[2010-07-08 10:51:30,352] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavutil     49.15. 0 / 49.15. 0
[2010-07-08 10:51:30,353] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavcodec    52.20. 0 / 52.20. 0
[2010-07-08 10:51:30,353] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavformat   52.31. 0 / 52.31. 0
[2010-07-08 10:51:30,353] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavdevice   52. 1. 0 / 52. 1. 0
[2010-07-08 10:51:30,353] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavfilter    0. 4. 0 /  0. 4. 0
[2010-07-08 10:51:30,353] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libswscale     0. 7. 1 /  0. 7. 1
[2010-07-08 10:51:30,353] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libpostproc   51. 2. 0 / 51. 2. 0
[2010-07-08 10:51:30,353] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   built on Mar  7 2010 00:34:41, gcc: 4.2.1 20070719  [FreeBSD]
[2010-07-08 10:51:30,353] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Input #0, mpc, from '/mnt/music2/L/Le Tigre/Le Tigre - Le Tigre/01 - Deceptacon.mpc':
[2010-07-08 10:51:30,353] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Duration: 00:03:04.55, start: 0.000000, bitrate: N/A
[2010-07-08 10:51:30,353] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: mpc7, 44100 Hz, stereo, s16
[2010-07-08 10:51:30,353] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Output #0, wav, to 'pipe:':
[2010-07-08 10:51:30,353] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: pcm_s16le, 44100 Hz, stereo, s16, 1411 kb/s
[2010-07-08 10:51:30,353] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream mapping:
[2010-07-08 10:51:30,353] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Stream #0.0 -> #0.0
[2010-07-08 10:51:30,353] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Press [q] to stop encoding
[2010-07-08 10:51:30,380] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) LAME: Can't get "TERM" environment string.
[2010-07-08 10:51:30,380] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) LAME 3.97 32bits (http://www.mp3dev.org/)
[2010-07-08 10:51:30,381] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) CPU features: MMX (ASM used), 3DNow! (ASM used), SSE
[2010-07-08 10:51:30,381] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) Using polyphase lowpass filter, transition band: 16538 Hz - 17071 Hz
[2010-07-08 10:51:30,381] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) Encoding <stdin> to <stdout>
[2010-07-08 10:51:30,381] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) Encoding as 44.1 kHz 128 kbps j-stereo MPEG-1 Layer III (11x) qval=2
[2010-07-08 10:51:30,874] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=     513kB time=2.98 bitrate=1411.3kbits/s
[2010-07-08 10:51:31,376] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=     963kB time=5.59 bitrate=1411.3kbits/s
[2010-07-08 10:51:31,885] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    1409kB time=8.18 bitrate=1411.2kbits/s
I am using the following settings :
Step 1 : ffmpeg -i %s -f wav -
Step 2 : lame -q 2 --cbr -b %b - -
Stab
Postby Stab » Thu Jul 08, 2010 11:58 am
It's definitely an mpc issue, I tried with an ogg file, and it worked perfectly
[2010-07-08 11:54:00,958] INFO PlaylistInputStream - admin listening to "Les Vieilles Salopes - Aime-Moi Tendre, Aime-Moi Vrai/Les_Vieilles_Salopes-(03)_La_grosse_tache.ogg"
[2010-07-08 11:54:00,966] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/mnt/music2/L/Les Vieilles Salopes/Les Vieilles Salopes - Aime-Moi Tendre, Aime-Moi Vrai/Les_Vieilles_Salopes-(03)_La_grosse_tache.ogg] [-f] [wav] [-]
[2010-07-08 11:54:01,065] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/lame] [-b] [128] [-] [-]
[2010-07-08 11:54:01,066] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) FFmpeg version 0.5, Copyright (c) 2000-2009 Fabrice Bellard, et al.
[2010-07-08 11:54:01,066] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   configuration: --prefix=/usr/local --mandir=/usr/local/man --enable-shared --enable-gpl --enable-swscale --enable-postproc --enable-avfilter --enable-avfilter-lavf --enable-pthreads --enable-memalign-hack --cc=cc --extra-cflags=-I/usr/local/include/vorbis -I/usr/local/include --extra-ldflags=-L/usr/local/lib  --extra-libs=-pthread --disable-debug --disable-sse --disable-mmx --disable-libamr-nb --disable-libamr-wb --disable-libdirac --disable-libfaac --enable-libfaad --enable-libfaadbin --disable-libgsm --disable-vhook --enable-ipv6 --disable-libmp3lame --disable-libopenjpeg --enable-libschroedinger --disable-ffplay --disable-libspeex --enable-libtheora --enable-libvorbis --disable-x11grab --enable-libx264 --enable-libxvid
[2010-07-08 11:54:01,066] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavutil     49.15. 0 / 49.15. 0
[2010-07-08 11:54:01,066] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavcodec    52.20. 0 / 52.20. 0
[2010-07-08 11:54:01,066] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavformat   52.31. 0 / 52.31. 0
[2010-07-08 11:54:01,066] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavdevice   52. 1. 0 / 52. 1. 0
[2010-07-08 11:54:01,066] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavfilter    0. 4. 0 /  0. 4. 0
[2010-07-08 11:54:01,066] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libswscale     0. 7. 1 /  0. 7. 1
[2010-07-08 11:54:01,066] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libpostproc   51. 2. 0 / 51. 2. 0
[2010-07-08 11:54:01,066] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   built on Mar  7 2010 00:34:41, gcc: 4.2.1 20070719  [FreeBSD]
[2010-07-08 11:54:01,127] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Input #0, ogg, from '/mnt/music2/L/Les Vieilles Salopes/Les Vieilles Salopes - Aime-Moi Tendre, Aime-Moi Vrai/Les_Vieilles_Salopes-(03)_La_grosse_tache.ogg':
[2010-07-08 11:54:01,128] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Duration: 00:01:51.44, start: 0.000000, bitrate: 130 kb/s
[2010-07-08 11:54:01,128] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: vorbis, 44100 Hz, stereo, s16
[2010-07-08 11:54:01,129] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Output #0, wav, to 'pipe:':
[2010-07-08 11:54:01,130] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: pcm_s16le, 44100 Hz, stereo, s16, 1411 kb/s
[2010-07-08 11:54:01,130] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream mapping:
[2010-07-08 11:54:01,130] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Stream #0.0 -> #0.0
[2010-07-08 11:54:01,159] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Press [q] to stop encoding
[2010-07-08 11:54:01,173] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) LAME: Can't get "TERM" environment string.
[2010-07-08 11:54:01,173] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) LAME 3.97 32bits (http://www.mp3dev.org/)
[2010-07-08 11:54:01,173] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) CPU features: MMX (ASM used), 3DNow! (ASM used), SSE
[2010-07-08 11:54:01,173] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) Using polyphase lowpass filter, transition band: 16538 Hz - 17071 Hz
[2010-07-08 11:54:01,173] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) Encoding <stdin> to <stdout>
[2010-07-08 11:54:01,173] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) Encoding as 44.1 kHz 128 kbps j-stereo MPEG-1 Layer III (11x) qval=3
[2010-07-08 11:54:01,666] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=     835kB time=4.85 bitrate=1411.3kbits/s
[2010-07-08 11:54:02,175] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    1633kB time=9.48 bitrate=1411.2kbits/s
[2010-07-08 11:54:02,675] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    2421kB time=14.06 bitrate=1411.2kbits/s
[2010-07-08 11:54:03,183] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    3203kB time=18.59 bitrate=1411.2kbits/s
[2010-07-08 11:54:03,691] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    4003kB time=23.24 bitrate=1411.2kbits/s
[2010-07-08 11:54:04,194] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    4803kB time=27.88 bitrate=1411.2kbits/s
[2010-07-08 11:54:04,715] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    5633kB time=32.70 bitrate=1411.2kbits/s
[2010-07-08 11:54:05,218] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    6465kB time=37.53 bitrate=1411.2kbits/s
[2010-07-08 11:54:05,724] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    7299kB time=42.37 bitrate=1411.2kbits/s
[2010-07-08 11:54:06,231] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    8099kB time=47.01 bitrate=1411.2kbits/s
[2010-07-08 11:54:06,737] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    8897kB time=51.65 bitrate=1411.2kbits/s
[2010-07-08 11:54:07,243] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    9697kB time=56.29 bitrate=1411.2kbits/s
[2010-07-08 11:54:07,754] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   10529kB time=61.12 bitrate=1411.2kbits/s
[2010-07-08 11:54:08,261] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   11361kB time=65.95 bitrate=1411.2kbits/s
[2010-07-08 11:54:08,769] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   12161kB time=70.59 bitrate=1411.2kbits/s
[2010-07-08 11:54:09,276] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   12929kB time=75.05 bitrate=1411.2kbits/s
[2010-07-08 11:54:09,786] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   13731kB time=79.71 bitrate=1411.2kbits/s
[2010-07-08 11:54:10,303] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   14562kB time=84.53 bitrate=1411.2kbits/s
[2010-07-08 11:54:10,808] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   15363kB time=89.18 bitrate=1411.2kbits/s
[2010-07-08 11:54:11,326] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   16195kB time=94.01 bitrate=1411.2kbits/s
[2010-07-08 11:54:11,840] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   17027kB time=98.84 bitrate=1411.2kbits/s
[2010-07-08 11:54:12,358] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   17860kB time=103.68 bitrate=1411.2kbits/s
[2010-07-08 11:54:12,858] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   18632kB time=108.16 bitrate=1411.2kbits/s
[2010-07-08 11:54:13,206] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   19200kB time=111.45 bitrate=1411.2kbits/s
[2010-07-08 11:54:13,207] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) video:0kB audio:19200kB global headers:0kB muxing overhead 0.000224%
Stab
Postby Stab » Thu Jul 08, 2010 5:15 pm
Up ?! :oops:
Stab
Postby delcypher » Wed Jul 14, 2010 10:32 pm
The issue appears to be using the web player in firefox. It appears to work fine using google chrome.
I've posted a dirty fix here:
http://forum.subsonic.org/forum/viewtopic.php?t=2939
delcypher
